Results 1 to 11 of 11
Thread: Shift light?
    Default Shift light?
    Hi guys,
    Just wondering if anyone knows of a shift light that works independent of an aftermarket taco... all the ones I've seen so far seem to work codependently with a (usually huge) taco... I don't want a super flash one either... just somewhere around the $50 mark, so long as it's reliable...
    '77 RA28LT #2 ← 2.2L 18RG...
    Default Re: Shift light?
    You're an engineer... make one for half that
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
    Not trying to be a Carport Converter
    Jan 2009
    I doubt there is many for $50, unless you can find one second hand. I remember seeing these in a magazine article ages ago, no idea if they're any good or cost etc. No idea how it gets it's readings etc, so might pay to ask
    Within the 100% Carbon Fiber case both shift lights feature a full Microprocessor sampling your RPM signal in 16bit resolution at 0.0000045 of a second (222,222 times per second).
    http://www.gizzmoelectronics.com/
    Jaycar make a kit called a frequency switch.
    Junior Member Grease Monkey toymaz's Avatar
    act
    I use a shift light from chiptorque http://www.chiptorque.com.au/products.html#sl
    wasn't that costly and small, you can leave the LED alone or put it in a little tube like i did.
    Junior Member Backyard Mechanic Sigmeister's Avatar
    Jaycar also do a multi-stage shift light. So has 3 lights. Green, yellow and red. And lights up depending on how you set it. Could have this or just use one of them. I paid around $32 for mine a few years back.
    Classic JC Quotes
    "A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster."
    "Usually, a Range Rover would be beaten away from the lights by a diesel powered wheelbarrow. "
    "The Mitsubishi 3000GT is about as sporty as a game of Darts."
    Chiba
    Shift-i make an awesome sequential shift light. You can get them for a good price from www.thetunersgroup.com
    http://www.tunersgroup.com/Online_St...ht_System.html
    I got one on my car and it's awesome.
    Thanks for all the suggestions guys, I'll look into them all...
    TERRA - What's required to hook that Shift-i up? will it work with a distributored ignition or is it one of those fang-dangled ignitor only ones?
    Timbo - I'm a mechanical engineer... not electrical. I wouldn't know where to start with something like that...
    Aug 2009
    Speco have a standalone shiftlight.
    The Gizzmo one is a nice little 2 stage unit.
    Project:RA65 with an engineered 1ggte conversion.
    Daily:MA61 - 5me stock auto shitheap.
    Chiba
    The shift-i just needs +12v, ground, and tacho input. You calibrate it to suit your system. I'll dig out the manual tomorrow and see what it says.
    Feb 2009
    MN
    look up the datasheets for the LM2907 and LM3914. there are circuits in the applications index in the back that, when combined, would pretty much make a configurable shift light.
  1. My custom quick shift (BIG PIX)
    By puzzle man in forum Tech and Conversions
    Last Post: 24-01-2011, 06:56 PM
  2. 3SGE alternator into RA28 charge light issue???
    By RA23_Procrastination in forum Tech and Conversions
    Last Post: 03-04-2008, 12:08 PM
  3. Ultra Small & light weight RWD idea.
    By Johnzoku in forum Tech and Conversions
    Last Post: 13-03-2008, 08:54 AM
  4. Help! MR2 Gearbox Shift Selector Removal
    Last Post: 06-06-2006, 12:30 AM
  5. you can light up your speedo with LEDS
    Last Post: 21-03-2006, 10:34 AM
