Results 1 to 15 of 17
Thread: Lower temp thermostat-where from?
    Default Lower temp thermostat-where from?
    I'm chasing a lower temp thermostat for my rwd 4agte. Does anybody have any sugestions on where to sorce one from? I'm after maybe a 78-9degree one.
    Craig.
    4agte Sprinter - 11.7 @118mph WSID
    2.45 @ mount panorama
    1.56 @ eastern creek, 1.10 @ wakefield
    1.24 @ oran park GP
    2.00 @ Phillip Island
    Default Re: Lower temp thermostat-where from?
    Last edited by jazae86; 18-03-2010 at 07:58 PM. Reason: after thermostat not temp sensor
    Jun 2009
    i bought a TRD thermo 71degree for mine cost bout $77. do a google search for them. rhdjapan or japanparts.com might have them for your motor and there pretty good.
    90' GT-Four ST185 RC motor ST205 gearbox!
    New installs Ct20B and Rear Strut Brace!!
    Next to come;
    3SGE cams, Fidanza Adj Cams, WolfKatz fuel rail!!
    Tallahassee, FL USofA
    Quote Originally Posted by cri_ag View Post
    Some manufacturer may still make them like they used to, with a threaded rod in the center that makes it easily adjustable.
    I have to ask why you want a lower minimum temperature?
    You could try castle hill toyota
    Quote Originally Posted by allencr View Post
    engine builder and very experienced racer suggested it may be a way to keep my fluctuating temperatures under control. along with a few other things. im racing Bathurst over Easter so i want to have have one in my spare parts kit to throw in if she starts misbehaving and see if has any effect.
    1.24 @ oran park GP
    cheers mate ill give them a bell.
    1.24 @ oran park GP
    wa
    i didnt think lower temp thermostats were any more expensive than factory spec ones.
    road and track stocked various temp thermostats last time i checked
    Junior Member Carport Converter ecko's Avatar
    May 2007
    tasmania
    go to repco grap a dayco thermostat on the back are the temps and diametres for other thermostats that may suit
    is it fluctuating at temp, or while warming up? or from low to warm temps?
    tried drilling a 3mm(ish) hole in the stat to have small but continuous flow until it opens?
    It's fluctuating at operating temp, at Oran park, it would be perfect all the way around the track untill just. Before the last corner then it would rocket up.
    1.24 @ oran park GP
    I'll try the dayco idea 2 c if anything fits. The 3mm hole was an idea sugested, I have one drilled ready to try if it starts missbehaving!
    1.24 @ oran park GP
    May 2007
    tasmania
    fairly sure all toyotas are 52mm which is good as dayco do sell a 73 degree thermostat from memory in that size
    sweet ill check the dayco catalog out cheers.
    1.24 @ oran park GP
    temp going up has nothing to do with thermostat..
    thermostat just stops temps going down. if the thermostat is full open at 78deg or 85deg, if the temp is 90 and then goes up to 110 (for example) the thermostat has no effect
    the hole thing just helps to stop the temp going down, from when the stat suddenly opens and floods engine with cold coolant from radiator.. keeps it a more constant temp while the thermostat is still closed
    perhaps the water pump is frothing up the coolant too much?
    are you losing coolant at all?
    perhaps it is just lack of cooling capacity (got the rad sealed so no air can escape around it?)
  1. 4AGE Water temp sender. How to troubleshoot
    By Howieau in forum Tech and Conversions
    Last Post: 03-05-2009, 09:48 PM
  2. cooling problems - collapsing raiator hose
    By Disturbed1 in forum Tech and Conversions
    Last Post: 14-04-2009, 07:53 PM
  3. 20 Valve Silvertop Thermostat availability?
    By dank in forum Tech and Conversions
    Last Post: 17-03-2009, 01:39 PM
  4. how many holes to drill in thermostat to increase cooling efficiency?
    Last Post: 17-11-2008, 05:00 PM
  5. 4A-C Thermostat & Temp Sensor
    By GasedT18 in forum Tech and Conversions
    Last Post: 20-07-2008, 12:29 AM
