What happens if you go through the gears manually? That is, put it in L and then take off and then put it in 2 and then put it in D. Does it do the same?
Why I ask is to determine if there is an issue with the automatic upshifting which doesn't occur when you do it manually.
Also, when cruising at (say) 60kph and you plant the accelerator, does it kick down from D and into 2 without a problem and when you release you foot does it go back to D without any issues? These are things that we need to know to help diagnose your problem.
seeyuzz
river
