Results 1 to 3 of 3
Thread: Carbon canister purging tech info needed
    SC14'd Member Domestic Engineer nick.parker's Avatar
    Canterbury
    Default Carbon canister purging tech info needed
    Can anyone please explain the operating strategy of the solenoid valve between the carbon cannister and vehicles inlet system (4agze) , and where on the manifold is this purge 'pipe' is routed? i.e. is it before the throttle (atmospheric pressure) or to the inlet manifold so it would potentially see vacuum and boost (depending on when the solenoid was operating of course)
    Thanks & Regards, Nick
    == 4AGZE SC14 Supercharged ==
    Junior Member Backyard Mechanic manny's Avatar
    Default Re: Carbon canister purging tech info needed
    This is more Toyota generic than 4AGZE specific, but will more than likely give you an idea of how the different Toyota variations work.
    Toyota EVAP Control Tech Doc
    GSE20 IS250 - daily
    Junior Member Backyard Mechanic gixer's Avatar
    If you are planning to change how this system operates, make sure you don't vent it at idle, you'll get a really rich mixture, worse on hot days!
  1. Some general tech info about engines/tuning
    By Hen in forum Tech and Conversions
    Last Post: 03-01-2006, 12:39 PM
  2. Replies: 12
    Last Post: 16-12-2005, 08:03 AM
