Results 16 to 30 of 44
Thread: supercharger recoat
    Junior Member Automotive Encyclopaedia eeeyan's Avatar
    Sep 2009
    Default Re: supercharger recoat
    i said replace it doesnt have to be new....
    Wish I had a F#%ken awesome toyota.. saving for the goodness now.... stay tuned....
    A warning to all others! Backyard Mechanic
    Dec 2009
    CA
    The days of just replacing them with another used one is quickly coming to an end. Almost everyone that has a car that uses these nowadays is running some sort of overdrive pulley on them, and when they get used up, they aren't worth squat.
    So long and thanks for all the fish!
    Sep 2009
    Thats true.. good excuse to turbo charge the bugger.
    Jul 2009
    Ditch the toy roots blower and go to twin screw, the time and effort in rebuilding the SC12's would be a decent down payment to a better, more efficient twinscrew unit
    Quote Originally Posted by knightrous View Post
    Even Magnuson is much better alternative. It all comes down to cost tho.
    Oct 2009
    Just squirt some spray paint on the worn rotors, should fill in the gaps nicely
    hahah
    Gearwhore. Backyard Mechanic
    Oct 2008
    If anybody has a spare blower sitting around in QLD, I will take the rotors in and get a quote for you guys.
    The above opinion is just that - my opinion. It is not shared by any business that I am currently or have previously been involved with, nor any of their employee's.
    Jun 2008
    Dear Q-Authority. I don't know about the US rebuilder but some years ago I purchased a so called reconditioned item and when I dismantled it when I got home I found it was in worse condition than the item I gave them as exchange. I was told all they do was get a lot of worn units and assemble the best parts to make their so-called reconditioned unit. I ended up getting my money back and put my old unit back in.
    someone call these guys? (or others that do same thing)
    http://www.dixonind.com.au/html/teflon.html
    these guys are in brookvale and recoat cookware
    http://www.peratex.com.au/
    TeflonŽ industrial coatings spray on like paint and bake to a tough, inert finish.
    The challenge is getting correct and consistent coating thickness where the lobes meet the casing and each other. 0.1mm to much and it gets ugly. 0.1mm not enough and your supercharger will have massive internal leakage.
    they coating is designed to wear away initially to be a good fit.
    perhaps you could help the process somehow
    Quote Originally Posted by oldcorollas View Post
    I'll send you some emery tape to help speed up the process, if you like?
    i was thinking more heat.. from boost.. but emery tape might work ... or sand...
    SC14'd Member Domestic Engineer nick.parker's Avatar
    Canterbury
    The rotors are some kind of aluminum alloy. The 'fluorine resin' (so called teflon coating) on the rotors is up to 0.5mm thick in places. Its more like a 'cast on' layer than a sprayed on coating. Typically 'coatings' that can be applied by high tech coating outfits will be a fraction of this thickness. I haven't yet come across anyone who can 'recoat' these rotors with an already set up process.
    == 4AGZE SC14 Supercharged ==
    Sep 2009
    If anyone looking for a spare i have one
    /hijack
  1. CFM and Liters for a supercharger? *Edit*
    By Radar in forum Tech and Conversions
    Last Post: 13-10-2009, 02:50 PM
  2. 14psi on turbo = 14 psi on supercharger?
    Last Post: 28-01-2009, 04:56 PM
