The CFM is proportional to the boost pressure and the engine size and rpm. (Boost pressure is fixed and is proportional to pulley ratio)
What you need to do is calculate the CFM required for your engine size and max rpm and required boost pressure.
Let A = Cubic Inch Displacement
B = RPM
D = VE (Naturally Aspirated VE %)
C = Boost in PSI
CFM = ((A/3456)*B*[(14.7+C)/14.7])*0.01*D
I.e. with a 103CID Engine revving to 7000rpm at 8psi requires 273CFM of air. (Estimated 85% VE)
Once you know the maximum air flow required for your engine, you can then choose a supercharger that is capable of delivering this airflow at the required pressure.
435cfm @ 8psi per rev doesn't make sense. Superchargers are usually rated in terms of volume per rev and not a volumetric flowrate per rev.
I have attached a spreadsheet i knocked up, so you just have to punch in some numbers.
(P.S. The spreadsheet is not exact but close enough).
Rudi
