Interesting thread.
Mass flow can be increased by either higher flow and/or higher pressure.
When it comes to the exact maths to calculating air flow through a particular head porting design, valve shape etc... there is no point comparing what one person has done vs another. There are too many contributing factors to how an engine will behave and what it is designed to do.
Yet, increasing pressure will increase the air speed. If everything else is constant.
The only way for more air to get through is for either the diameter of the greatest restriction to be increased (flow), or for pressure (air speed) to increase.
As Newtons Laws of Physics state that everything wants to balance, hence a high pressure will try to equalise with a low pressure. The greater the difference the more potential energy that wants to equalise with the lower energy. If the diameter that the mass has to pass through is constant then then only way for more to pass is by the speed increasing.
Obviously with valves opening and closing and with all to consider on an IC engine there is more to consider.
Yet increasing pressure will speed up flow.
To test this just go and plug an air tool like a die grinder into an air compressor and see what speed it runs at different air pressures. The pressure will effect the air speed through the turbine in the air tool. If you want to try experimenting with air densitly then try it on days of a different temperature.
Air condenses when cold and is heavier. One of the reasons for intercoolers, the other being colder air is less prone to detonation.
Similarly, turn on a tap. The pressure is constant, yet as the restriction (diameter of the pipe gets larger) more water flows.
Back to engines though, it really depends what you are after. In my opinion for a street motor, all A series heads flow O.K. Prob would go for 20V or small port 16V.
Yet for top end power for dedicated race cars, especially when the engine has FI, the big port head is the best option. It has large enough runners for flow, and pressure from FI will increase air speed. Will have the best mass flow yet may not have much power down low but who is driving a race track below 4000rpm with a 4AGE?
Both pressure and flow decide how much mass flow makes it into the combustion chamber. The more air the more power. Just depends at what revs, how the engine behaves and what the use for the vehicle are as to what size runners and how much pressure should be used.
