Results 16 to 27 of 27
Thread: how to replace head gaskets on a 1uz-fe
    jay zee zee thir tee Carport Converter HAVABEER's Avatar
    Default Re: how to replace head gaskets on a 1uz-fe
    http://www.filefactory.com/file/b069...300_Manual.pdf
    don't take this guide as perfectly accurate as its meant for soarer's and might be differnt to your car
    also shouldn't this thread be in the technical one not general car talk?
    Nov 2009
    Quote Originally Posted by HAVABEER View Post
    Yes you are right it should be in the technical. It wasn't how i thought it would go when i posted it. MY bad
    Nov 2009
    I have a soarer engine
    I still need the engine service manual ?
    Nov 2009
    Today I total rebuilt the top end of my motor every thing accept the heads
    I hope I got all the water leaks.
    is there anybody out there with an engine crank trigger disc they would cell me
    for my Soarer motor 1uz-fe.
    Actually I need the later model version with the 36 or 38 or so teeth. or even 12
    Nov 2009
    do a search for a download able version of the soarer bible
    it does both a 1jz and 1uz basic rebuild and will tell you how to do the head gasket. i have a copy here and will up load it to one of those free file hostings tonight for you if i remember.
    Hello
    I cannot find a down load site for the soarer bible can you help cheers rod
    ahhh the link to the file is in my last post... its the under lined bit
    once your there scroll down in click this button
    just be aware its a tricky manual to navigate as there is no index
    Nov 2009
    Thanks Sometimes I must be blind. . it was very obvious when i looked
    I am very grateful for the file PDF
    Tyre smoke in m eyes
    You want to be really sure you need to take the heads off before you do it
    As you cant re-use the head bolts so you will be up for $$$ for a new set of bolts as well as head gaskets (These are cheap though, you can get complete top-end gasket sets for an engine off ebay for around $100)
    Nov 2009
    Yes I agree the bolts are expensive.
    I have changed all the water gaskets on the top of the motor and i am now reassembling it
    will wait and see before i do heads I don't want to do the heads I hope all is good now
    Why do you wnat a different crank trigger?
    I have a set of custom cam angle sensors that can replace all that toyota multi-tooth trickery if you like.
    Facebook | LinkedIn
    Nov 2009
    Quote Originally Posted by stradlater View Post
    I want to customizes the the computer and i have a preferd setup i like to use
    I don't want to destroy the original one on the engine
    do you have one?
    Nov 2009
    well I have changed all the top end seal and gasket. NOT the head Gaskets.
    and no more water leaks engine all going again.
    thanks for your help guys
    smoke gets in your eyes
  1. Replacing head bolts with studs.
    By PHOBIA in forum Tech and Conversions
    Last Post: 17-09-2011, 11:36 AM
  2. 4age head gasket - lend me your thoughts
    By predator in forum Tech and Conversions
    Last Post: 25-01-2010, 09:21 PM
  3. Where in au to buy metal head gasket?
    By omy in forum Tech and Conversions
    Last Post: 22-06-2006, 06:36 PM
  4. 4a head gaskets
    By DeftAnesthetik in forum Tech and Conversions
    Last Post: 20-06-2006, 05:51 AM
