Results 1 to 15 of 23
Thread: 3 stripped bolt holes on boss kit - advice?
    Dec 2009
    Default 3 stripped bolt holes on boss kit - advice?
    Hey everyone,
    I picked up a steering wheel and boss kit online second hand and once i got it home I found that 3 of the bolt holes which are holding the wheel on are completely stripped. The bolts were still visible through the stripped threads and the previous owner has just used 3 nuts.
    I'd like to do it properly if I can. Is there any way I could get new holes drilled and tapped legally?
    Its for a st184 celica.
    I am not sure if the steering wheel seemed to be out slightly when lining up to the boss kit.
    I'll try get a photo
    The reason I wanted to use this wheel is because the padding section of this wheel is completely covered.
    ZZT-231 Toyota Celica SX
    Penrith BC
    Default Re: 3 stripped bolt holes on boss kit - advice?
    helicoil them
    ../delete/ban
    tech moderator
    Dec 2009
    Quote Originally Posted by ed_jza80 View Post
    helicoil them
    I'm not sure if i'd have the distance to actually wind in a helicoil
    Interesting suggestion though thanks
    Jul 2008
    nutsert it
    As said, helicoil is prbly going to be your easiest solution.
    i.e.
    Bah too slow.
    Is weld and redrill an option?
    Nutserts don't ussually sit flush which may cause issues.
    Wilbo's JZA80
    Wilbo's JZZ12
    Oct 2008
    TAS
    is it alloy or steel? i'm guessing steel,
    prob easier to get another boss it for $30 than stuff around for a hour trying to fix it.
    just my 10c.
    1983 Toyota Celica Supra
    Dec 2009
    Quote Originally Posted by CELICASUPRA7M View Post
    just my 10c.
    Yea i'm tempted to just get another,
    I'm not too sure if its alloy or steel. Its a nardi wheel
    The other option was just to redrill new holes by rotating the boss kit a few degrees
    Oct 2008
    TAS
    yeah i'v redrilled and tapped a steel one before, if i had to do it again i'd just buy one lol.
    Dec 2009
    I mean't to say it was a Nardi boss kit not a wheel lol
    I'm hoping the boss kit will come with a horn button as well. I'm looking for one at the moment too
    Dec 2009
    I was also wondering if there was any legalities to the shape of a steering wheel? Does it have to be perfectly round? In the vic roads page it doesn't mention anything regarding that
    Tallahassee, FL USofA
    Quote Originally Posted by trd_st184 View Post
    x2
    just drill out the hole that is there (should be around m6) to the next size up and tap, shouldnt take long or be hard.
    if u buy a new one ill take this one off ur hands and do just that for my daily
    Never late in an x8
    Dec 2009
    What gets me is that this is the only wheel to have a padded centre that i've been able to source out
    I've found out that the previous owner of this wheel has drilled out the holes on the actual steering wheel to match the boss kit (they seem to be slightly out)
    Is there any steering wheels I could buy which are around 330mm that have a covered centre pad?
    dude- i wouldnt be using that at all if it were me. get your money back and buy something decent. Momos and some of the top line brands have padded centres. cheapies wont
    Dec 2009
    Yeah good advice StuC,
    I'm wondering if anyone knows whether a stock subaru steering wheel would fit? They all look like the same shaft thread so I'd imagine there is no reason it wouldn't fit.
    By The Witzl in forum FAQ
  2. Bolt FAQ
    By dogeatdog01 in forum Tech and Conversions
    Last Post: 18-02-2008, 04:52 PM
