"EFI" and "ENGINE MAIN" relays would be a good start.
you will need a number of fuses as well. I guess you could put 5 or 10 amp in and see which ones make the relays work
you could use a multimeter to see which fuses are connected to the relays.
Hello
Im trying to start a 3s-fe engine and i have a problem
there are missing thinks that i dont know what they are
can any one help me by :
* telling me wich of them is important to start the engine ? or show me any picture of this box full
( i dont care about lights - turn lamps - glass cleaning & heater & other motors )
* giving me a link for a 3S-FE wiring diagram
At a sign on vehicle wrote : 3s-fe -87 * sv21
my english are not very good so forgive me for any mistakes
Last edited by river; 21-02-2010 at 10:06 PM. Reason: ambiguous title for tech section
efi is a 15 amp fuse
I'd just pop down to the wreckers and take the whole fusebox.
Or grab all of the fuses/relays/fuse links from one
There are heaps of wreckers around that will have camrys
ZZT-231 Toyota Celica SX
dont forget this guy is in greece in what appears to be a rural area.. but yes the engine main and toyota efi and corresponding fuses.
1990 Aus Delivered Widebody GT4 Play 200 awkw
1996 HDJ80. turbo multivalve 80 series landcruiser
1997 HZJ80 Landcruiser Sold![]()
1993 Soarer V8 Manual Sold![]()
1986 Celica SX Sold![]()
i found a manual finaly here http://www.camrystuff.com/
seems like is ok but i dont hear the fuell pump to work
i have to check the ground points again
Thank you for your help
Well the pump is rusty , i need a new one ,
http://i605.photobucket.com/albums/t...o/DSC01885.jpg
thats easy but...
Somehow a plug is cutted , im trying to find the cable of the fuel pump and
i need to know one information
When the key is turned at ON (lock - ACC -ON - - Start) is the pump working for a few seconds ?
If you know or you can test it by hear your camry please let me know
My camry has never had any pump priming when switched to ON.
If you still have the AFM (air flow meter) turn the key to ON then press the flap inside the AFM open and you should be able to hear the pump.
you can use the pump from an st184/st185 celica, or vzv21 camry. if you have trouble finding one i can send you my one but postage might be a bit.
Thanks for your offer i dont know what im gona do whith the fuel tank
another , so im not sure what type of pump i will need
Im looking for the pumps cable and your informations will helps me to find it
Thanks again
John
The engine starts
if you like to see a 3S-FE starting again after years take a look here
http://www.benzworld.org/forums/unim...ml#post4069025
http://www.benzworld.org/forums/unim...ml#post4075347
Thanks for your help again
