if i put a ra60 strut and ra40 strut up against each other there wont be much difference between each other ,so i follow to under stand your comment ,you will only get positive camber if you put a smaller arm like 20 mm smaller than std 1,as soon as you put a longer arm in you will always get neg camber and also will get postive toe out with the longer arms, the wheels point out wards, it wont change caster at all
