Results 16 to 25 of 25
Thread: Fuel pump running for 2sec after shut off?!
    Feb 2009
    Perth W.A.
    Default Re: Fuel pump running for 2sec after shut off?!
    damm it, that is confusing now.
    By the way that click is possibly the circuit opening relay.
    I took one out of a toyota camry and it was kind of in behind the cd player on the car body.
    Hung like planet Pluto... Backyard Mechanic Rcubed's Avatar
    QLD!
    Quote Originally Posted by rob View Post
    the 1G-GE did this in my RA40 as well
    it still does!! and has an annoying ticking noise at the end.
    this is normal unfortunately. in the circuit opening relay above you can see there is a capacitor and resistor in series with the L1 solenoid coil. when shut off [either by key or AFM [however mine is MAP]] that arrangement will hold the cct on while the capacitor 'leaks' charge [there is a proper name for this but IDK] thru the coil.
    1. There's no point arguing with an idiot. They'll just drag you down to their level and beat you with experience
    2. Don't argue with an idiot; people watching may not be able to tell the difference
    Feb 2009
    Perth W.A.
    So the capacitor in the circuit opening relay is powering the high performance fuel pumps for 2 seconds after it is shut off?
    I dont know much about electronics, but would a small capacitor be able to run the pumps just on residual charge?
    QLD!
    also the diagram above is incorrect for the 1G-G at least. the L1 solenoid is powered to the ECU at the FC pinout and the other side is connected to battery thru Main Relay switch. the MREL pinout holds this power on, and is also switched by ECU
    QLD!
    Quote Originally Posted by Rota View Post
    the capacitor in the cct above powers the solenoid which keeps the relay switch closed
    Nov 2007
    So I take it it's the capacitor that allows the fuel pump to run for 2 seconds until it discharges? Or is there a special relay that remains on for 2 seconds after power off?
    Feb 2009
    Perth W.A.
    Quote Originally Posted by ta23-mbzq-nnr View Post
    Ok this is all starting to go over my head hahaha
    Do you know why the ecu is holding the "main" relay power on?
    can we power the main relay from the ignition rather than the ecu power?
    Cheers for the help
    Looks like you are right and it isn't correct. My appologies. I'll fix it up in a sec.
    I did look at the 1G diagrams that I also had, but it seems 1G-E was the same as I posted which must have been what I saw at my quick inspection, and assumed all the 1G were the same (Incorrect).
    Cheers for the help
    Read this thread
    http://www.toymods.net/forums/showth...28#post1077728
    Going off ta23-mbzq-nnr diagram the ISCV is powered from the same relay that powers the fuel pump.
    Wilbo's JZA80
    Wilbo's JZZ12
    Feb 2009
    Perth W.A.
    So can we leave that relay there and run a new one off the ignition for the fuel pumps?
    Nov 2007
    When i stripped my old soarer I didn't find this one, maybe I missed it but are some located in the ECU? Or Never?
  1. AE93 fuel pump, what power can it support?
    By MrRolla in forum Tech and Conversions
    Last Post: 27-12-2008, 07:45 AM
  2. Twin Carb fuel setup
    By soulfire in forum Tech and Conversions
    Last Post: 18-12-2008, 02:38 PM
  3. Picking Best Fuel Pump..!
    Last Post: 10-09-2007, 03:15 PM
  4. Mounting fuel pump (intank)
    Last Post: 24-01-2006, 09:49 AM
  5. Replies: 1
