Results 1 to 2 of 2
Thread: AE93 fuel pump, what power can it support?
    Jun 2006
    Default AE93 fuel pump, what power can it support?
    Hi guys,
    Im looking at buying a 4agte (AE101 ZE motor) powered GTi corolla, now as far as i know its still running the standard fuel pump from when it was 4age. car is running a RB25 turbo on 9 psi on standard injectors and ECU.
    what sort of FWKW can the standard pump support before it would eed to be replaced and what pump would you recomend. ideally with new injectors and aftermarket ECU id be happy with around 160-180FWKW so a pump that can support this would be great..
    91 4AGZE SX Hatch.
    98.8kw@ wheels (Standard Boost)
    15.01@89MPH (Standard Boost )
    senior backyard mechanic Grease Monkey legend's Avatar
    Default Re: AE93 fuel pump, what power can it support?
    why not just replace it with an aftermarket pump there only $140 ish
    or u could rely on the 10 yr old std pump to fail and cost u motor
    bosch ,walbro
  1. 2JZ less power after pump upgrade
    By thrashlux in forum Tech and Conversions
    Last Post: 11-08-2008, 06:34 AM
  2. 1JZ Fuel Pressure Regulator Limits
    By beasht in forum Tech and Conversions
    Last Post: 19-04-2008, 05:17 PM
  3. Looking For Cheap Power! 20v Silver Ae93
    By SXY in forum Tech and Conversions
    Last Post: 23-01-2007, 06:35 PM
  4. weak fuel pump? (1jz-gte lost alot of power)
    Last Post: 23-01-2006, 08:14 PM
