what sort of tint did you get, dyed or metalised? for $35 it sounds very cheap, i would only ever use the metalised stuff..
a kind of mate of mine has done 4 cars for me and i've given him a hand on the last 2.. it's not really that hard..
you'll need
a wind free invironment like a double garage enough to open both doors easily..
a green scotch brite pad
stainless steel cartridge razor blades (a few)
squirty bottle with some morning fresh/water in it
squeegee
very fine meatal nail file
heat gun
talcom powder
squirt the glass inside AND outside with the soapy water,
scotchy the glass area,
then run over it with the razor blade scraper,
then squeegee
do that to all the side windows, the rear window ONLY scotchy over the inside of the glass, unless you don't want to keep your demister!
SIDE WINDOWS
step 2 - cut the tint to size..
squirt some fresh soapy water on the outside of the window..
place the tint onto the outside of the glass (it will stick with the soapy water there)
allow about an extra half inch, around the edges..
once cut to approx size, pull it off the glass, and peel the protective backing layer off the tint, and as quickly as possible spray the exposed sticky tint with the soapy water.. don't be scared, you cannot use too much of it.. it won't hurt your interior trims..
once you get it to sit right and down the bottom rubber about half an inch or so.. spray some more water on the fresh tint and sqeegee it in an outwards motion.. this might take a few goes to get the right idea.. but it's pretty easy..
once squeegee'd then trim the hanging over bits to size with the razor blade..
once trimmed to size with the blade, to get that extra neat finish use the fine metal file on the edge of the glass, in ONE DIRECTION ONLY file towards the ourside of the door, right round all the edges.. this is the finishing touch (you only do this on the top egde with framed windows in other cars) it helps reduce the chance of the tint peeling off when the windows get wound up,
repeat that for your sides..
REAR WINDOW
the rear window is a bit trickey.. but still easy..
clean the outside of the window as mentioned before..
cut one large peice of tint to cover the whole window
sprinkle some talcom powder onto the outside of the window, and just wipe a hand width line across the middle of the screen, place the tint over the rear window, and cut to size to make this easier.. put a light or lamp etc inside the car on the back seat, and allow about an inch or so (little less maybe) covering the black out on the glass..
CUT to size..
NOW use a heat gun to lightly melt a bit of a shape to the tinting.. not too much or you will wrinkle the F%%k out of it.. just enough to shape a bit of a curve for the glass in it..
pull it off.. shake off the talc (it's only on the protective backing anyway)
peel off, wet and stick inside the rear screen! squeegee!
your car is tinted!!
a little tip he told me with frameless windows..
leave the windows down a TINY bit, just so the top of the tinting isn't hard against the rubber seal at the top of the glass.. just so it doesn't dry with a line.. don't have to.. but it doesn't really hurt it to..
enjoy
