Results 1 to 11 of 11
Thread: Silvertop Oil Leak ?
    Jan 2010
    Default Silvertop Oil Leak ?
    G'day,
    today on the track i noticed an oil leak
    it looks like its coming from the flex plate between the engine and gearbox at the front of the engine in front of the thermo fan.
    Its fairly black oil and my engine oil is freash so i assume its gearbox oil
    Where is the oil most likely coming from? is it common to leak in this area?
    thanks
    Default Re: Silvertop Oil Leak ?
    rear and front seals respectively. To get to the rear you take the flywheel off and then unbolt it's housing and the front by memory requires you to take off the pulley, lower cover, belt retainer plate, belt gear drive and then the housing. Sounds like someone put too much oil in
    Junior Member Grease Monkey TRD-12A's Avatar
    Nov 2009
    i agree defanetely rear main oil seal and front engine seal.
    it might not be too much oil could be blocked PCV system or the seals have just gone hard from not regularly changing the oil
    true that about the PCV, the ones on a 20v are stupidly small. Pull it off the head and blow air through it both ways, should only work one way.
    Jan 2010
    Thanks fellas
    Where is the PCV located ?
    its that little plastic thing that does a 90 degree bend out of the cam cover near the oil filling point. It has a hose going into the chamber above the intake manifold. Just grab it and pull it out. Only the rubber seal holds it in so it's no issue doing it that way.
    Jan 2010
    No problems with that PVC.
    I noticed when i toke the oil cap off with the engine running a fair bit of air was coming out is that normal?, when i rev it up it tends to go away or no blow out as hard
    Chiba
    When you rev it, the rings seal tighter due to the increased combustion pressures. An amount of blow by is normal, even more so for an engine this age.
    Jan 2010
    Fair enough.
    I pulled the box out this morning. I toke the fly wheel off and its abit wet around the back of the block but i was expecting there to be more oil. The flex plate was oily.
    Seems alot of oil around the gearbox and when i toke the speedo drive out i swear i heard a washer fall into the box..
    Can anyone confirm the part number/s for the rear main seal? Which is best, should i buy it from toyota?
    FELPRO BS40409 , BECK ARNLEY 052-3258, CORTECO 17199
    mUnk
    Jan 2010
    Default Rear main
    I got genuine part # 9031170007 $62 from toyota.
    What gearbox oil is best for the 5spd?
    WTB 15'' Rims
    20v AE82 Track Car - WP 1.17.7
    20v AE82 Street Car: Going Really Well
    Falcon ute, Slippin auto & a worn steerin rack
    Chiba
    75w-90 is what you want.
    I spent the money on Royal Purple, as the oil is seldom changed, and I want my box to be looked after.
  1. CT12A Oil Leak (Rear).. Need advice
    Last Post: 25-03-2007, 07:28 AM
  2. AE102 -> SIlvertop conversion?
    By birdie in forum Tech and Conversions
    Last Post: 11-09-2006, 08:34 PM
  3. Boost Leak Tester
    Last Post: 01-06-2006, 11:25 AM
  4. finding an oil leak.
    By AE101LEV in forum Tech and Conversions
    Last Post: 01-03-2006, 06:26 PM
