Results 1 to 11 of 11
Thread: 7M Cressida engine removal
    Aug 2009
    Default 7M Cressida engine removal
    Hey has anyone removed a 7M to do rings etc then put it back in. How hard is it?
    Before anyone carries on about 1J, 2J etc, that is out of my budget this moment, just want reliabilty from 7M for the next year then conversion time
    Default Re: 7M Cressida engine removal
    disconnect auto & remove starter
    remove radiator
    remove all intake piping & throttle cables etc
    take off a/c compressor & p/s pump. leave in engine bay
    remove exhaust manifold. leave in engine bay
    undo engine mounts if they arent already busted
    lift out motor
    loosen timing belt tensioner
    remove head -leave cams in & inlet manifold on
    remove sump
    remove big end caps
    push pistons out of bores
    hone bores
    re-ring pistons
    install pistons & big end caps
    reinstall head & timing belt
    drop motor back into engine bay.
    connect auto, accesories & ex manifold.
    reinstall radiator
    fill with appropriate fluids (use a running-in oil for the first few k's)
    bed the rings in with heavy load and lots of engine braking
    profit?
    Never late in an x8
    Aug 2009
    Difficulty scale 1-10, 1 being easy, 10 being impossible? Does the engine come straight up easily?
    hard for me to say ive done it a bunch of times now having had the car for 6 or 7 years. its not super hard, inline engine in rwd format give plenty of room. can be done in a day (removing it that is)
    the actual lifting it with the engine crane can be tricky, if the engine mounts arent broken they tend to catch here and need some prying to get off. a good tip is to undo the top bolt on the mount where the motor sits and also take out all (i think 3) bolts that hold the mount to the xmember.
    as for doing the rings, would depend if uve done this or built an engine before.
    Never late in an x8
    Aug 2009
    No worries. I am in the process of buying a car and was going to be a cressida. If so, then probably have to do the head at least in some stage that I own it. lol Another member was selling their cerssida and he said it needed rings so I was just seeing as to who might have done this before to guage how difficult it may be..
    head is a piece of cake and the job can be done easy in a weekend if u can get it machined quick enough on a saturday arvo (not always easy to do!)
    re-ringing one is a bit more work and its hard to not go overboard while its apart
    Never late in an x8
    Mar 2008
    inner west syd now!
    my mate and i were able to remove the top half of the motor (7mge-mx83)in about 4hours, if we had a hoist, i am sure we'd would of been able to take the motor out(in a single day, the exhaust bolts wouldnt come loose so that would of slowed us down, but your best to take the gbox out with the motor, makes likes a lil easier IMO....most of the day he was just standing there watching me, his first time doing anything massively mechanical btw (this was Friday just gone btw, so sweltering heat slowed us down a bit aswell! aswell as food!
    Slanted Photographer Automotive Encyclopaedia LeaThaL's Avatar
    Aug 2006
    in basicly a day with the auto attached still we removed the 7m from one and 1jz from the other and traded both over, fitted 1jz and got running and fitted 7m so it wouldnt fall out,
    for the 7m. if you know what your doing to a degree for a 1-10 id say maybe a 6. just tricky getting the bellhousing bolts if you dont have enought/proper tools/extensions etc etc
    non turbo makes it easyer also
    1 G L O V E
    88 Ga70 supra --- Under powered and over cooled Daily
    Apr 2007
    piece of piss, if it takes you more than a day to get it out then theres something wrong.
    just disconnect and label everything, and lift it out out engine+gbox together. if you wanna do it easy, then drop the crossmember out with the engine attached. not sure how much of a bitch this is with an MX83, but with my Z20, the crane was about 2inches short of having enough reach to get it all in the right position to get it out and back in over the top. nothing that a bit of muscle wont fix though.
    defintely easier the drop the entire crossmember+engine+gbox than to lift it over the top.
    Mar 2008
    inner west syd now!
    i thought the PS rack was attached to the x-member??? which is was hinders you from "drop the entire crossmember+engine+gbox than to lift it over the top."
    .....if we had a hoist we coulda ripped it out, but i didnt think that (with his skill level, basically a newbie) that we would of been in the position to rip it out but we were...i cant get the manifold bolts off, thats wat slowed me down!!!
    Aug 2006
    well we did it on a mx83 not a month ago, we ended up having to drop the whole thing back together due to restrictions with moving space, a hill on driveway and man power but over the period of 1pm-7 we managed to totallly remove the xmember and swaybars, get the body up, relise that we cant do it and the crane was gunna drop the body soon due to a short chain so we dropped it back down, bolted it all up again and then removed the 1jz and piss the body off outta the way .
    and totally agreed that doing the whole thing with the motor and gearbox together as i hate having to do all the little bolts on the back of the Toqure converter
    1 G L O V E
  1. How to build an NA engine...
    Last Post: 05-07-2014, 11:48 AM
  2. MA70 --> JZA70 Conversion
  3. 1j engine fan removal
    Last Post: 30-01-2007, 02:24 PM
