disconnect auto & remove starter
remove radiator
remove all intake piping & throttle cables etc
take off a/c compressor & p/s pump. leave in engine bay
remove exhaust manifold. leave in engine bay
undo engine mounts if they arent already busted
lift out motor
loosen timing belt tensioner
remove head -leave cams in & inlet manifold on
remove sump
remove big end caps
push pistons out of bores
hone bores
re-ring pistons
install pistons & big end caps
reinstall head & timing belt
drop motor back into engine bay.
connect auto, accesories & ex manifold.
reinstall radiator
fill with appropriate fluids (use a running-in oil for the first few k's)
bed the rings in with heavy load and lots of engine braking
profit?
