if it was me i would run twin 044's down twin stock size fuel lines and filters and convert your fuel rail into twin entry type. only cos 044's are good for a proven 350rwkw each approx and your better to have too much fuel rather than not enough. 1l surge should be fine but i wouldn't be to confident with a 20yr old lift pump. consider maybe a holley or facet low pressure lift pump (not expensive). external mount surge and 044's would be best for noise, legality (if engineered), safety and will stop the horrid smell of feul in the cabin. wiring and plumbing not hard. as for the 14v, the 044's will run quite happily like this and wont heat fuel noticeably. not sure about the stock pump![]()
