Page 3 of 3 FirstFirst 123
Results 31 to 39 of 39
Thread: 4AGZE loses power at 5500rpm
    Default Re: 4AGZE loses power at 5500rpm
    I've seen it on AE92 MAP GZE's.
    Ireland
    +1 on a friends AE92 MAP GZE pulling timing but not on another friends AE92 AFM GZE, my AE101 GZE with fmic can be 50/50. Has anyone tried a new knock sensor instead of 2nd hand sensors from other engines?
    GZE Love Grease Monkey PsyCo's Avatar
    Jan 2009
    My problem is definately triggered on startup. I can drive the pants of it make the problem go away. Turnb the car off anmd restart and it comes straight back.
    JP suggested the STA wire might be incorrectly wired which wouldn't suprise me. The wiring isn't what I'd call good even by my standards.
    California
    It sure sounds good to hear that people are still trying to elude the 5500 rpm power drop. I have yet to do it but seems as though there may soon be a solid solution. Lets see some dyno plots as consistancy is key. Curious to know what you guys do about fuel cut at 15psi?
    Ron
    Ireland
    I fitted a new knock sensor and it's not as bad but still noticeable
    Jul 2010
    might be better to incorporate a notch filter into the knock pre-amp if it only happens at a certain RPM theres no need to remove the knock sensing capabilities outside that frequency, also some form of attentuation on the knock sensor could do the job too but im not sure how this would affect genuine knocking.
    i could have a go at chopping something up too, maybe try a different path to you terra and see what works ?
    California
    Quote Originally Posted by JP View Post
    +1
    Happened to me with my sc 14 and Ae92 map based Ze.
    Ron
  8. #38
    if anyone needs any circuit design, pcb manufacture, etc, etc on this let me know as I am keen to assist if others are strapped for time. let me know if I can help out!
  9. #39
    California
    I would love to be able to use the stock ecu and power to redline like most performance cars on this planet do. If there is a circuit that will allow me to get there, then I am all for it. Keep in mind I also have an aftermarket ecu, but would not have gone that route if powering to redline where an option.
    Ron
  1. Aristo JZS147 Stereo Install (Part 1 in a Series)
    By infotechplus in forum Tech and Conversions
    Last Post: 24-01-2008, 10:57 AM
  2. 4ag wiring issue, power to ecu but no power out??
    By SLO-055 in forum Tech and Conversions
    Last Post: 16-11-2007, 11:31 PM
  3. 3sGTE Intermitant 30-40% power loss
    By worldwalker in forum Tech and Conversions
    Last Post: 26-07-2007, 05:41 PM
