Results 1 to 15 of 26
Thread: what brand lsd is this?
    Default what brand lsd is this?
    I have a 2 way lsd here. Can someone identify it for me
    Jealousy is a curse
    Default Re: what brand lsd is this?
    surely it has a part number stamped on it?
    compared to the diffs I've seen, it looks a bit.. agricultural
    is it in a bogwarmer?
    not a toyota diff?
    a bit more info as to model of the housing might help
    Quote Originally Posted by oldcorollas View Post
    not a toyota diff?
    It is a Lexus IS200/SXE10 7.5inch F series 4.1 ratio
    It was purchased with the expectation it was a stock LSD and this is what we got . We prefer the stock Torsen LSD so this has to go
    Jealousy is a curse
    ahh, IRS..
    doesn't look like CUSCO http://page21.auctions.yahoo.co.jp/jp/auction/j60847285
    or like KAAZ http://page14.auctions.yahoo.co.jp/j...ion/s158681452
    stock looks liek this http://page5.auctions.yahoo.co.jp/jp/auction/e95229350
    the outer casing looks reasonably similar (rough and machined bits) to this TRD G except for the round holes
    http://page18.auctions.yahoo.co.jp/jp/auction/w46073467
    and again http://page.auctions.yahoo.co.jp/jp/auction/131072725
    AH! we have a winner!!
    TRD 2 way 7.5"
    http://page13.auctions.yahoo.co.jp/jp/auction/r61851531
    and yours
    Thanks for that . Almost the same angle although the housing is different. I had a look on Yahoo Japan and did not see that one
    Jealousy is a curse
    no worries
    this section
    and search lsd 7.5
    hmm, GX90 and GX100 and GXE10 have all the holes in the outer tabs drilled (top right)..
    but GX71 doesn't.. must be GX71 housing or similar early model? later model has dowels(altezza only?) and extra holes
    Cover looks like this
    Jealousy is a curse
    ?? that's just stock IS200 fare
    (from stock altezza torsen link above)
    Yes it is a IS200 housing with Torsen replaced with TRD LSD
    Jealousy is a curse
    no backyard Domestic Engineer japlish's Avatar
    that look's almost identical to my jzx90 diff?
    Destroyer of 'Drop Forged' spanners
    Quote Originally Posted by japlish View Post
    internally or externally?
    the JZX series LSD housings (internal bits) i saw on yahoo looked almost identical , except they didn't have the round holes in the side of the LSD casing... the other casting/machining looked almost same.
    JZX90/100 are G series, S/GXE10 IS200s are F series (both are marked as A on the build plates though I think)
    I'd pick is as a TRD diff as well, cast casing is a giveaway...agricultural as well apparently
    Junior Member Backyard Mechanic gixer's Avatar
    Quote Originally Posted by madmont View Post
    Just out of curiosity, can I ask why you don't like the clutch plate lsd and prefer the torsen?
    I have a trd 2 way in my AE86, which I like, all my previous cars have had clutch plate lsd's which I like, I have an AE111 daily which has a torsen fitted and I don't like at all in the wet....lsd, what lsd!!!, having said that tho, the other week I took it around the track and it worked well, but it was dry.
