Results 16 to 24 of 24
Thread: 4a forged/aftermarket/oem piston identification help...
    Default Re: 4a forged/aftermarket/oem piston identification help...
    what the heck are you guys talking about?
    early, low comp, stock 4AGZE bigport piston.
    looks like a circlip groove in there?
    They're factory GZE pistons, ART make them for toyota, more pics etc here:
    http://www.rollaclub.com/board/index...howtopic=11168
    Is a Self Employed Grease Monkey wombat's Avatar
    I wasn't sure so I thought I'd ask.
    what the? I thought all the bigports had no circlips or groves for it?
    ART is common on a lot of factory toyota pistons.
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
    i think it might be this company.. ART Asama
    http://asama-piston.co.jp/index.php
    edit: from 99
    this...
    http://www.art-piston.co.jp/
    http://www.art-piston.co.jp/products.htm
    A warning to all others! Backyard Mechanic
    Dec 2009
    CA
    Those are definitely, absolutely, positively 4agze pistons. They are low comp versions, which use relatively shallow valve cuts. I would suspect similar pistons, with deeper valve cuts, as being hi-comp versions.
    I recently bought a new set of 81.5mm os 4agze pistons for my '89 SC, and they are identical to those, except for the icky carbon deposits. Fortunately, you took photos of the undersides, which have the same identical markings as mine. They will all have the ART stamping, plus, what I would assume is a batch number that will vary from batch to batch, etc. Everything else is exactly identical, including the valve cut reliefs, pin hole postion, etc.
    And yes, 4agze pistons use fully floating wrist pins that requite circlips, and yes some people have used later 8.9 hi-comp pistons when building both turbo and sc applications, though I'm not sure that many really understand their purpose. To my knowledge they were introduced to help alleviate low rpm power issues, and are usueable for this due to the more advanced fuel, ignition, and engine designs that can compensate for the higher compression at boost.
    So long and thanks for all the fish!
    Feb 2007
    Timaru
    Quote Originally Posted by Q-Authority View Post
    Yes, the higher compression gives them more response off boost, which makes them better to drive and also as there is more power down low, makes boost come on earlier.
    Higher comp pistons are definatly the go, if you can get the fuel and detonation under control.
    Higher compression means the same power at less boost.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
    the depth of the cuts is identical (afaik) but the different dish makes them look different.
    = they both have same anti-valve-smacking specs...
  1. 22R piston dimensions
    By joecoolmk2 in forum Tech and Conversions
    Last Post: 03-10-2009, 10:53 AM
  2. confusion over acl/mahle piston specs
    Last Post: 26-03-2008, 12:01 PM
  3. 4agze piston specs needed
    By rotated7 in forum Tech and Conversions
    Last Post: 27-06-2007, 07:27 AM
  4. Gudgeon(Piston) Pin + Piston + Rod Matching
    Last Post: 13-03-2007, 08:24 AM
  5. Tool to safely remove piston rings??
    Last Post: 07-03-2007, 11:26 AM
