The powerfc unit itself uses a common pinout for all non vvti JZ vehicles (A70 A80 X81 X90 Z30 & possibly more) the yellow loom adapter is what dictates which vehicle it suits. The unit itself is designed for and natively fits the Z30/X90. Further to that a JZA70 powerfc can start and run a JZZ30 soarer without the use of the loom adapter. Im assuming here the same can be said for each model combination providing the correct loom converter is used.
Correct. However it does let you adjust ignition timing and fuel injection against intake and water temperature.PowerFC does not allow adjustment of ISCV (idle speed control valve) in relation to temperature as far as I know (JZA70 R is able confirm).
You need to be more specific in regards to describing the problems you're experiencing... what exactly happens? (if ive missed it sorry)Originally Posted by deck star
Generally if your car isnt operating 100% then there is something wrong, and buying aftermarket parts hoping that they will fix it isnt really the solution. You need to isolate the problem first.
