Results 1 to 6 of 6
Thread: 4agze head bolt socket, HELP
    Junior Member 1st year Apprentice fatRA28's Avatar
    Aug 2006
    Default 4agze head bolt socket, HELP
    Hi, i need a diameter for the head bolts off a pre 90 4agze and number of points on the star pattern head bolt, eg, is it the same as 4age?
    i have a part number for the socket 09205-16010 but its for 4age, having trouble finding the correct gasket set and tools and bolts.
    number of points and size will help if i need to ring around to see if anyone has tools to fit or the bolts themselves.
    thx
    Aug 2006
    Default Re: 4agze head bolt socket, HELP
    ive found that 4age head bolts are 10mm double hexagonal, ill go with them hoping they are the same as 4agze,
    hopefully ill find a socket now, but still looking for the correct gasket set to suit my model, a few have looked a little different so far, toyota here in wollongong is useless for help.
    Victoria, Mt Macedon
    I've always based 4AGZE stuff off 4AGE. For example you'll be fine using a 4AGE gasket set (choose bigport or smallport accordingly) for all things bar the obvious (SC inlet and outlet gaskets, TB gasket).
    And I used a 12 point 10mm socket to get at the headbolts. A normal 3/8" drive socket on an extension bar fitted fine, there wasn't enough room to get a 1/2" drive socket down there.
    Hen
    Aug 2006
    Thank you
    Aug 2006
    Just another question, vrs kit for an ae82??
    I dont know the specs for the head gasket thickness on either my 89 model gze from an import ae92 or the ae82 4age, will i have issues with this gasket kit with comp ratio etc ??? thx.
    Aug 2006
    anyone??? trying my best not too screw this painfull task up,lol
    By The Witzl in forum FAQ
  2. 4agze bigport blown head gasket
    By punkture in forum Tech and Conversions
    Last Post: 24-11-2009, 06:09 PM
  3. 4AGZE AW11 MT Flywheel bolt torque
    By McFly 11 in forum Tech and Conversions
    Last Post: 10-12-2007, 10:54 PM
  4. 4age head bolt tool?
    By muzwaldo in forum Tech and Conversions
    Last Post: 29-01-2007, 01:01 PM
  5. Matching your head to your o-ringed block.
    By PHOBIA in forum Tech and Conversions
    Last Post: 09-05-2006, 03:14 PM
