Results 1 to 15 of 18
Thread: 1JZGTE, CT12A Replacement question
    Jul 2009
    Default 1JZGTE, CT12A Replacement question
    Hey guys
    I will be replacing my buggered ct12a's soon, will i require any new gaskets?
    Or can i use the original ones?
    Matt
    Nov 2007
    Default Re: 1JZGTE, CT12A Replacement question
    Best to get new ones as old ones may or may not leak.
    Jul 2009
    the oil line doesn't use gaskets and the ones for the dump and exhausts are metal right?
    where can i buy new gaskets?
    Im about to take on this project.. how hard is the swap while engine in car?
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    your mums an Carport Converter pato's Avatar
    matt, the standard metal gaskets between the head and exhaust mani, are fine to reuse.
    there probably better than buying new crappy ones really
    Quote Originally Posted by RAd28
    I certainly don't need to stick my hand in a blender to know it'll cut my fingers off, and i don't need to weave in and out of traffic at 120 to know it's fucking stupid.
    Nov 2009
    W.A
    Call Toyota genuine for hard to find gaskets. Just got a heap for my 1ggte, there not as expensive as you might think and it saves alot of time looking.
    Current Rides:
    -1988 GZ20 1ggte, undergoing head rebuild and single turbo conversion.
    -Fully sick Hyundia Getz (work car).
    i can get u part numbers if u want.
    just send me a pm
    no backyard Domestic Engineer japlish's Avatar
    just smear some copper max silicone over the oem gaskets and you should be fine.
    turboRA28: best to put aside a whole weekend to change turbo's over and if you have any small handed friends tell them to come over for a ""barbaque"".............
    thats average.. it took half a day to put the engine in so maybe easier to remove and do it out of the car.. does look very tight..
    ive done it both ways,
    and id be allmost inclined to say that it is in fact easier to take the motor out and do it
    requires use of a friend with small hands/wrists/arms, and also a contrived combination of socket extensions and uni joins. And liberal application of Inox/WD40.
    And swearing. Lots of swearing.
    Nov 2007
    Agree with Draven, I did mine on a 1g-gte, The most annoying thing was getting at the bolts for the oil drains. Then there is random supports that bolt from the block to the turbos for extra rigidity I believe, this was on a 1g-gte, but you'll find even on the 1jz it's an annoying job to do without pulling the motor.
    Thing is the old gaskets will be squashed when taken out, so when you re-apply them, they might leak where as new ones will get squashed when you apply them and create a good seal, but you could re-use the old ones if you want to.
    As for that copper max stuff, Isn't the maximum temperature rating 500 Celcius? Doesn't the exhaust near the turbos get over 500 Degrees? Or does that stuff still hold up?
    Thanks.
    Jul 2009
    So i was thinking of using that Copper max silicone stuff http://www.permatex.com/products/Aut...sket_Maker.htm Is rated to 371 Degrees, how well will it hold up in a turbocharged application?
    turbo > 500 degC
    to be hones, your old gaskets will probably be fine - I've reused 1j and 2j gaskets after crushing, no leaks
    Aug 2009
    youd be stupid to reuse the standard manifold to turbocharger gasket after going thru the bullshit which is taking them off....
    and from factory they are a crush gasket.. meaning basically the first time you torque them down and get it hot... its now ready for the bin if you take it off again.... but id still use them if they were that new..
    but seriously.. for the price of them from toyota... and the age of your standard ones.. get new ones, my recommendation is toyota genuine ONLY... man the amount of aftermarket turbocharger gaskets ive blown that havent even lasted a week have made me learn that genuine is best..
  1. 1GGTE+Blitz CT12 turbos+1JZ CT12A guts = 250rwkw??
    By BLK1g-gte in forum Tech and Conversions
    Last Post: 30-01-2009, 10:23 PM
  2. Question for FWD owners..
    Last Post: 24-06-2008, 02:00 AM
  3. Wiring Stupid Question
    By zuludan in forum Tech and Conversions
    Last Post: 18-05-2008, 12:45 PM
  4. 1JZGTE Water Pump removal... A question or 2...
    By ZZT231 in forum Tech and Conversions
    Last Post: 26-05-2006, 08:47 AM
