Results 16 to 18 of 18
Thread: 1JZGTE, CT12A Replacement question
    Jul 2009
    Default Re: 1JZGTE, CT12A Replacement question
    I have gone ahead and ordered some turbo to manifold gaskets, but is there any gasket maker that will hold up in a turbocharged application?
    I wouldn't mind putting a little bit around gaskets for a bit of insurance.
    Nov 2007
    Look for ones that are specifically recommended for use on Exhausts, they're surely to have quite high temp ratings.
    Quote Originally Posted by pandaah View Post
    youd be stupid to reuse the standard manifold to turbocharger gasket after going thru the bullshit which is taking them off....
    swapped CT12A's many times and have never replaced this gasket. its embedded into the flange and as long as you clean the faces and tighten the turbo properly you shouldnt have any problems.
    only gaskets ive ever replaced are the oil feed/drain gaskets on the core and thats because the black plastic layer was flaking away. water lines i used silastic to reseal. have never used liquid gasket on any other surface other than the water lines. manifold gaskets are almost indestructable.
    to answer the OP's original question, imo no if they are all in good physical condition. inspect them well.
    JZA70|R / 12.45 @ 111 mph.
  1. 1GGTE+Blitz CT12 turbos+1JZ CT12A guts = 250rwkw??
    By BLK1g-gte in forum Tech and Conversions
    Last Post: 30-01-2009, 11:23 PM
  2. Question for FWD owners..
    Last Post: 24-06-2008, 03:00 AM
  3. Wiring Stupid Question
    By zuludan in forum Tech and Conversions
    Last Post: 18-05-2008, 01:45 PM
  4. 1JZGTE Water Pump removal... A question or 2...
    By ZZT231 in forum Tech and Conversions
    Last Post: 26-05-2006, 09:47 AM
