Results 1 to 13 of 13
Thread: Parking lights and dash lights not working - ra23
    Aug 2008
    Default Parking lights and dash lights not working - ra23
    Default Re: Parking lights and dash lights not working - ra23
    The biggest problem with your post is regarding the fuses - "they appear to be ok" check with a multimeter or systematically switch them. With any trouble shooting, it's important to make sure you actually rule out the variables properly. See my signature for the golden rule...
    The 15A 'Tail' fuse supplies a lot of things, including the parkers and the dash lights. It also controls license plate light, tail light, and potentially some others.
    Make sure it is OK, and do what Shelldrake said. If you don't have a meter, swap the 'tail' fuse with a known good one (wiper/turn?) temporarily to see if the problem remains.
    If the problem is still there, look closely at the 6-pin headlamp relay in the engine bay, or the actual headlamp switch on the stalk.
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
    my ma61 has the same problem, but keeps blowing the taillight fuse instantly... i opened under the steering wheel to find a birdnest of god know what goes where wiring - ill keep you posted if i find anything helpful
    THE OFFICIAL TOYMODS BOGAN
    MA61 - sunroof., 7MGTE, 4.11 lsd, w58
    MA61 - Built 2JZ, 9" diff, big brakes -1st car + the toy
    LN167 - dual cab fourbie, gu patrol chassis + suspension/ driveline, built 1.5jz
    Junior Member Grease Monkey TRD-12A's Avatar
    Nov 2009
    A multimeter or even a testlight, you have to check the fuses properly to rule them out otherwise your gonna be chasing your tail.
    If all ok there you then check power to headlight switch and then power coming out of headlight switch going to the parker circuit
    Aug 2008
    Aug 2008
    Aug 2008
    Nov 2009
    No you can't but your better off upgrading to a new relay anyway
    Buy a 5 pin relay 20-30 Amps
    If you need help wiring it in let me know
    Aug 2008
    So was the headlight relay the cause of the parkers/dash/ taillights not working?
    Aug 2008
    Aug 2008
  1. dash lights not working
    By vlas in forum Tech and Conversions
    Last Post: 30-04-2009, 03:21 PM
  2. dash lights lexus ls400
    By litldv8 in forum Tech and Conversions
    Last Post: 16-11-2008, 08:23 AM
  3. RA23 Dash Wiring
    By fuzz! in forum Tech and Conversions
    Last Post: 15-09-2008, 12:57 PM
  4. Behind Dash lights for A70
    By sleek3 in forum Tech and Conversions
    Last Post: 04-07-2006, 04:08 PM
