Results 16 to 30 of 46
Thread: W5x clutch pedal issues/Slave issues?
    West Australia
    Default Re: W5x clutch pedal issues/Slave issues?
    well i managed to sort this out
    by re-bleeding the master + slave for around 20 mins using a syphon tecnique there was ever so SLIGHT bubbles in it still
    i then adjusted the rod on the back of the pedal to raise the pedal height.
    WD40 was needed , but once applied the rod was moveable by finger power.
    Pedal is now useable, but not perfect. it can now has around 150mm of engagement (if you know what i mean) which is enough to be safe.
    Very happy with results and looks like i shouldnt have panic'ed so much
    BK Grease Monkey bk_'s Avatar
    Thanks for the info from that forum, Admiral coFF33.
    Moving the rod in towards the master cylinder helped resolve my problem, too!
    BK.
    West Australia
    im just gonna bump this up
    coz its gotten worse again
    My master is not leaking, but the pedal feal and pressure is absolute shit.
    I think when no pressure is on the pedal (ie. ive taken my foot off it) the pedal sits from the floor about 35mm
    the rest of the pedals sit 60-70mm off the floor and have normal feel to them
    Can anyone tell me why my clutch is soooo hard to push and so annoyingly low point for the engage/disengage
    What can i check that i aint done already?
    Would a new slave cyl maybe help ? seeing as i bought a new master?
    Tallahassee, FL USofA
    Quote Originally Posted by Admiral coFF33 View Post
    Clutch fork cracked & flexing?
    Nothing else besides the pedal height and the MC freeplay, in that order.
    The old slave will either leak or not leak and unless your problem is air in the system needing frequent bleeding & top up, or a clutch that slowly engages while your foot is still planted on the floor, a new slave won't make any difference.
    West Australia
    checked it over the weekend during engine transplant fork and bearing is fine.
    also, the clutch was changed from the exceedy (which also had same issues) to a stock clutch (that came with teh new 1GGTE)
    so its not clutch related
    if i could describe it even better id say this
    The clutch in a normal car has a somewhat "bounce back" to it. it also is very light and easy to push down with the "bite" point say mid way through the push, The push range from all the way up, to floor of the car is generally 120 - 130mm or so
    My w55 clutch:
    There is basically NO bounce back, if there is its only the pressure from the master cyl pushing back ever so slightly. fully released its ~50mm off the floor, The bite point is ~20mm off the floor, when pushing it down the 50mm its VERY hard and stiff to push.
    im gonna replace slave this arvo and bleed again
    will post progress
    How did you go coff? It still all sounds like it's not bled properly.
    sounds like you need a new clutch pressure plate.
    I have the same issue with my ST162
    I have changed the master cyl and slave cyl, and the whole clutch line inbetween. Even tried winding out the clutch spring all the way.
    nothing has fixed it - so has to be something inside the gearbox
    drop the gearbox out this weekend and add a new clutch kit - should be right as rain
    Damo
    Not in the diner Alf! Conversion King RyleyMA61's Avatar
    i had issues somewhat similar to yours... the pedal would only spring back about 50% of the way and ground into gears
    did turn out to be the pedal adjustment... only did it until i had full travel again and it worked a treat... kinda irrelevant to you thoughn
    Quote Originally Posted by WA_TRD_83 View Post
    Don't you think it's probably not the pressure plate, given he had similar symptoms with the old clutch
    West Australia
    Damo
    VVVV
    But thanks damo
    Ryley : The pedal has been adjusted to the maximum point with the 12mm bolt in the back of it (that is essentially the plunger for the master) if i adjust it anymore the bolt/nut fall out
    I put a brand new slave on yesterday arvo, bled it for around 30 mins , i was using clear tube so i was 200% certain there was NO bubbles left in the fluid
    The slave i got fits fine and its not to short or long, When compressed it does push out to the maximum (~40-45mm)
    The clutch is still the same
    Pedal is still hard which is ok , but is still engage/disengage right at the floor
    So now:
    replaced clutch
    master cyl
    slave cyl
    bled system ~8 times
    maybe its just something i have to live with
    Stupid question. But is the clutch fork that you are using the correct one for that bellhousing? I remember reading somewhere about a very similar issue and it turned out he was using the wrong fork.
    I can't imagine you've made this mistake coFF33, but if this helps at all, then mission accomplished. Otherwise I just sound like an idiot.
    West Australia
    Good call Phoenix, im completely unsure about that
    Stomps said the box was factory manual W55 , so i dont think anything would have changed re:Bearing/Fork ..
    but ill pm him and ask .
    yeah dude.. factory w55... was behind a 1gge in the gz10 i got... all we changed is add a T...
    we didnt change the fork or anything like that... it all worked perfectly when i had it...
    apart from the clutch that was in it from factory lasting exactly 1 drive before failing...
    the only issue we had was that the bearing didnt come with the exedy clutch i got.. it was missing for some reason and doing it at about 10pm, we couldnt exactly wait to get another one.. so we reused the factory one... still worked fine though..
    Stomps
    West Australia
    Yeah i know bro
    and when i drove your GZ10 in and outta my driveway once i got it home
    the clutch felt amazing like the one in my JZZ20.
    but now
    no
    Hmm oh well figured I should suggest it. Back to the drawing board then I guess.
    It just started to sound like a leverage issue (lack of it). Short effective travel, and hard to push.
  1. Made my clutch hydraulic... It doesnt work, c last post
    By TIMTAMS in forum Engine & Driveline Conversions
    Last Post: 16-02-2008, 06:17 PM
  2. Brake MS sizing vs pressure question
    Last Post: 08-09-2006, 10:22 PM
  3. Replies: 24
    Last Post: 18-04-2006, 01:42 PM
