what fuel economy is 'more' ?
hello
to quote cruzida/peewee
thread here - http://www.toymods.net/forums/showpo...42&postcount=41UZ's should get 12-14L around town (depending on how heavy your foot is) and 9-11L on the highway (per 100km's).
This is with aircon off.
Any 1UZ that is not in this region (and is being driven nicely) has issues somewhere (or is in a very heavy car)
To get better fuel economy there is a lot that can be done.
New cats ($400ish)
Clean injectors ($300ish)
New plugs ($120ish)
New leads ($250ish)
New dizzy caps ($90ish)
New rotors ($50ish)
New o2 sensors ($120ish)
Clean AFM ($15)
Clean ISCV
Clean TB
You just have to weigh up whether you are willing to spend the money only to get either a minimal result, or potentially no result at all.
RA23 - Twincharged
JZZ20 - Daily
clogged up catconvertor. Auto may need a service. Or you got some realy nasty fuel
o2 sensor maybe
I would start by checking the output of the o2 sensor. Ussually this can be done through the Diagnostic port, I know on my Soarer the Diag port has an "ox" terminal so you can check the output of the o2 sensor with a multimeter.
It's worth it to get your injectors cleaned, one way or another cleaner you'll know your injectors are good.
This might be a longshot, but fuel tank leak?
Fuel line leak?
Ok, thanks for the tips guys.
I will check the Temp sensor and the O2 sensors and let you know if it made any differance.
Nah man, I have never changed it in the 2 years i've owned the car. I should and will soon.
How would the fuel filter cause excess fuel consumption? Wouldn't, if anything, it cause less fuel to get through if dirty?
Thanks
JoJo
EDIT: Just wondering guys, are the RYCO fuel filters ok with the Celsior? I just checked and they are $52 so I'd imagine the Genuine ones would be much more...... Are they worth it?
THE OFFICIAL TOYMODS BOGAN
MA61 - sunroof., 7MGTE, 4.11 lsd, w58
MA61 - Built 2JZ, 9" diff, big brakes -1st car + the toy
LN167 - dual cab fourbie, gu patrol chassis + suspension/ driveline, built 1.5jz
as I aleady asked, how could the fuel filter cause it to use more fuel?
To me it sounds people are just saying things without actually knowing, albeit a couple. Injectors are a possibility but normally unlikely. The coolant temp sensor as a couple have stated has a bearing on fuel consumption. If it is not working correctly it will give mixed temperature readings (hot or cold) to the computer, the computer then feeds in however much amount of fuel it may need. But with a wrong reading to the computer it could be pouring in fuel.
1JZ MZ20 Soarer - 4AGZE KE70 Corolla - 4AGE AE86 - 4AGE KE70
