Results 1 to 6 of 6
Thread: replacing a 22r
    tas
    Default replacing a 22r
    Im just intriguied to whether an 18rg will bolt in the place of a 22re in an 85 corona.
    in being the same series engine "R" will it bolt upto the w55 thats in my car and will the engine mounts be close to that of the 22r. Im a bit bored of the 22re as its no power house which is fine but its not even fun to drive. Plus its knocking fairly severly now so i need to replace it.
    Cheers Josh
    Default Re: replacing a 22r
    Yes it will bolt in easily, bellhousing and engine mount bolt patterns are the same. You may need to swap sump and oil pickup depending on what the 18R-G comes with but that's pretty easy.
    Note that for legality you will need to get your hands on a late-model 18R-GEU.
    Junior Member Grease Monkey 50RTD's Avatar
    May 2009
    Can 18R head go on 22R bottom?
    What about turboing the 22R? I did look at it years and years ago for an old Bundera i had, but decided against it as they already have enough dramas with headgaskets!
    But if you could get a metal head gasket and arp bolts, the thing would probably hang on to 10psi of boost with the right fuelling etc. Just have to ask one's self if its worth spending money on a 22R when 1UZ's or 1JZ's are so cheap....
    Quote Originally Posted by 50RTD View Post
    No, not without a lot of machining anyway.
    Hell no.
    Nov 2007
    engine mounts are in different positions
    South Australia- Where the RIGHT Lane is the NEW LEFT LANE!!! *@#$&
    1974 280SEL Mercedes Benz
    1979 RA40 Sillycar
    1991 Subaru Liberty Heritage
    2010 Great Wall X240
    Nov 2007
    Well been doing a 21r into the 40
    The mounts can be moved forward on the 21r block putting then in the right position.
    the passanger side needs to be modified a bit to work.
    1979 RA40 Sillycar
  1. Replacing head bolts with studs.
    By PHOBIA in forum Tech and Conversions
    Last Post: 17-09-2011, 12:36 PM
  2. Replacing a Coaster's 22R with 1GGTE
    Last Post: 19-04-2008, 11:03 PM
  3. Need help: Identify these 22R plugs
    By infotechplus in forum Tech and Conversions
    Last Post: 23-01-2007, 05:42 PM
  4. RA60 to 22R
    By mullett in forum Tech and Conversions
    Last Post: 31-07-2006, 12:10 PM
