There's three types of cranks but you're only likely to come across one of them.
The two unlikely ones are the very early 4AGE, which had a 4AC crank with six bolts to hold the flywheel on, and then the big-port crank which has 40mm big-end journals. The most common these days is the small-port & 20v & GZE crank which has 42mm big-end journals.
The 42mm crank is good for over 400hp.
They are all steel.
