Results 1 to 3 of 3
Thread: AE92 4AFC problem
    Team Awesome Carport Converter Pimpin_1JZ's Avatar
    Bunbury W.A.
    Default AE92 4AFC problem
    I've got a problem with my 4AFC in my AE92. What is happening is under load it seems to cut all power from the engine. After it has cut out it takes a fair while for it to start again.
    Things I have gone through and cheked;
    -Plenty of spark from the plugs
    -Fuel pump pumping nice strong spurts
    -Cleaned carby out twice
    -Checked timing all lines up great
    -Cleaned all contacts in dizzy
    -Fuel filter has been replaced
    -All fuses check out fine
    Any other ideas? I'm fresh out.
    1JZ MZ20 Soarer - 4AGZE KE70 Corolla - 4AGE AE86 - 4AGE KE70
    Junior Member Grease Monkey TRD-12A's Avatar
    Nov 2009
    Default Re: AE92 4AFC problem
    Does it do it only when its at normal op temperature or all the time??
    wa
    I think they have an igniter on the side of the dizzy next time it cuts out spray it with some contact cleaner or freeze spray too cool it and see if it starts.
    By The Witzl in forum FAQ
  2. SX strut bar into AE92 (non SX)
    By Grega in forum Tech and Conversions
    Last Post: 23-03-2008, 08:15 PM
  3. ...so i did a headgasket 4AFC poo = dead
    Last Post: 12-02-2008, 06:52 PM
  4. ae92 proportioning valve and master cylinder
    Last Post: 14-01-2008, 09:01 PM
