A shroud increases the cooling efficiency of the system. You need the fan operating when stationary or at low speeds. An unshrouded fan is moving air only through the portion of the radiator equal to the surface area of the fan. Shrouding your radiator lets the fan pull air through the entire core.
I don't know if there is much difference between push vs pull on the fans, but I am not sure if a shroud on a push fan would work as well as a shroud does on a pull type set-up.
Also, at higher speeds, when the fan is not required, I think the push type fan would offer more obstruction to air trying to get into the radiator, as opposed to a pull type.
Most people seem to go for the push type due to space restrictions, other wise the pull type with shroud is the preferred method. Well, it is for me.
seeyuzz
river
. I used to run this setup on my last engine combo and it was great!
