I'm running the 1st one
the 2nd one almost looks home made![]()
Hey guys,
Well seems like there is two different push pull converter for an 1J R154 OS Giken clutch.
do both work the same for the R154 box?
Or which one will i need for the 1J R154 box?
Pics
This type?
OR this one?
Thanks
-Sleeper 2J + R154 X83
-GQ 93 Mav, 4.2 Diesel, 35" BFG KM2's, 4" lift, 3" Exhaust, Front Locked, Rear shimmed, Sliders, IPF foggies, UHF, 2871R and Intercooled.
1990 JZA70 R - BLMQZ
m a n u a l
Dark green mica
14.118 @ 101.01 mph (Perth Motorplex, 24/05/06)
252.1 HP (Hyperdrive, 11/11/06) / 264.2 HP (XSpeed, 24/02/07)
Im running the first one as well.
I snapped the mount points pictured on the left and had it replaced with billet (already snapped and rewelded once before in Japan).
I think the 2nd pic is a later (more solid) version to combat the inherent weakness of the pivot point.
600 Club Member: Toymods Large Member
MegaP00 - 7MGTE Skunkworks division
RIP - Nathan Dean (TA-022)
BlackSupra is on the money - the first cast type was prone to cracking and the second one was a much stronger revision.
There is a third beefier cast type from pictures I've seen which may be a later revision. I've used 3 different sets of the second type on various cars/engines and never had a drama with the movement kit on the street or the track - it's seriously over engineered.
Lube up all those moving parts liberally with appropriate lubricant otherwise it will dry up, bind and get pretty heavy on the left leg.
GSE20 IS250 - daily
Ive got the outter housing of the second one here if anyone has the rest of it, then they can make themselves up a complete unit..
