Results 1 to 5 of 5
Thread: 4agze-taking head off
    Default 4agze-taking head off
    with a 4agze in a front wheel drive corolla, how do you undo the bolts on the underside of the inlet manifold? do you have to take out the motor or can it be done with the motor in the car? Also, how many bolts are there?
    Junior Member Backyard Mechanic benjamin's Avatar
    Default Re: 4agze-taking head off
    Can you get at it from underneath? There are four bolts and I am pretty sure that they are 12mm.
    And have you taken off the supercharger? The top of the sc is held by the inlet manifold.
    can't get to it from underneath, does the sc have to be removed?
    Jack be nimble...small hands, but you'll need to take the SC off...
    RM.
    No, you dont need to take the intake manifold off. You can simply take off the top mounts of the SC and the four bolts on the back of the throttle body. The rest is the same as usual, only you take the intake manifold as well. Beware though it completely unbalances everything though., the back end will drag it back a bit.
  1. Replacing head bolts with studs.
    By PHOBIA in forum Tech and Conversions
    Last Post: 17-09-2011, 11:36 AM
  2. 2s to 3sge head swap?
    By sam-131 in forum Tech and Conversions
    Last Post: 24-03-2007, 06:42 PM
  3. 4agze conversion
    Last Post: 02-03-2006, 08:52 PM
  4. 1G Taking off the head?
    By Ray_GZ20 in forum Tech and Conversions
    Last Post: 26-02-2006, 01:36 PM
  5. 4AC broken head - remedy?
    By slapper in forum Tech and Conversions
    Last Post: 25-01-2006, 05:59 PM
