Page 44 of 65 FirstFirst ... 34424344454654 ... LastLast
Results 646 to 660 of 975
Thread: Winton 6 hour 23-24 oct 2010
  1. #646
    Dec 2009
    Default Re: Winton 6 hour 23-24 oct 2010
    hi graham
    its more likely the diff
    as phillip island is notorious for killing diffs
    as the long sweeper drains oil down the diff tube leaving SFA for the crown wheel and pinion
    this is the reason we used to overfill the diff still had plenty of oil to lube everything
    just need a pvc tube on the vent to make oil escape more difficult
  2. #647
    While you have the axles out you might as well do the axle bearings at the same time... i think a kit is about $30 an axle from CBC.
    There is a thread here some where on toymods about making some simple baffles for the axle tubes too if you want to get really carried away!
    Now - RA23-WRX
  3. #648
    Eddie (shelldrake), Andrew (af300e), Stephen (RA40-Rossco), and I were all out on track at Winton yesterday.
    Times below are taken from NATSOFT - http://www.natsoft.com.au/cgi-bin/re...26/09/2010.WIN
    Session 1
    Car - Driver........- Laps - Fastest Lap
    135 - shelldrake...- 6.......- 1:47.33 (Lap 4)
    114 - af300e........- 5.......- 1:49.24 (Lap 3)
    136 - twentyEight - 6.......- 1:50.31 (Lap 6)
    5 - RA40-Rossco - 6.......- NA
    Session 2
    135 - shelldrake...- 3.......- 1:50.41 (Lap 1)
    114 - af300e........- 6.......- 1:48.67 (Lap 4)
    136 - twentyEight - 0.......- NA
    5 - RA40-Rossco - 5.......- 2:01.59 (Lap 1)
    Session 3
    135 - shelldrake...- 6.......- 1:45.07 (Lap 6)
    114 - af300e........- 6.......- 1:48.46 (Lap 3)
    5 - RA40-Rossco - 5.......- 2:00.19 (Lap 3)
    Session 4
    135 - shelldrake...- 6.......- 1:44.39 (Lap 3)
    114 - af300e........- 6.......- 1:48.63 (Lap 6)
    136 - twentyEight - 6.......- 1:52.32 (Lap 4)
    5 - RA40-Rossco - 5.......- 2:02.19 (Lap 5)
    Session 5 - NATSOFT display's the fastest times of the day for each driver rather than Session 5's results, luckily I remember mine, and shelldrake and RA40-Rossco's times were their fastest of the day.
    135 - shelldrake...- ?.......- 1:44.32
    114 - af300e........- ?.......- ?
    136 - twentyEight - 5.......- 1:51.22
    5 - RA40-Rossco - ?.......- 1:57.35
    ([][][]II--LT--II[][][])
  4. #649
    You were all fast! How was reliability?
    Now - RA23-WRX
  5. #650
    I had some radiator issues.
    First I had a pinhole leak from the top, so Andrew soldered it up for me and we applied some kneadable epoxy to some developing cracks which held. I also replaced the radiator cap with a new one as the old one I had on there was looking pretty bad on the inside, but the only one the parts store had was a 100psi cap. On the last session the heater core decided it would relieve the pressure instead of the radiator cap, and put all the coolant in the passenger floor well whilst out on track with the wife as passenger so I retired 1 or 2 laps prior to the session ending (ps. she loved the experience and is a lot less worried about me being out on track now that she's seen how well the car handles).
    Luckily, I have a new alloy one that I didn't get a chance to install prior, and will put a shut off valve on both heater pipes so that I can bypass the heater core (when I find a working one) for track days.
  6. #651
    Dec 2009
    compared to what Adam??
  7. #652
    Quote Originally Posted by shornesheep View Post
    Compared to the speed of the majority of our team competitors in years past.
    Now - RA23-WRX
  8. #653
    Here are some numbers to back up my assertions taken from the race, not the practice, so they might be a bit slower or a bit faster on the day given it was regularity not racing
    Its kinda interesting looking at the history and progress made too!
    2008
    Brad - Corolla 4agze - 1.48.04
    Phill - Mini - 1.49.31
    Adam - Corolla - 1.50.47
    Cam - Corolla - 1.51.00
    Tim - Levin - 1.53.09
    Shannon - Celica - 1.53.32
    Ian - Celica - 1.53.49
    Graham - Celica 0 1.54.22
    David - Mini - 1.54.38
    Eddie - Celica - 1.55.82
    2009
    Matt - GTR - 1.44.26
    Jeremy - Sprinter - 1.46.41
    Joel - Celica - 1.46.46
    Eddie - Celica - 1.47.06
    Andrew - Celica - 1.48.03
    Darryl - Anglia - 1.48.80
    Steve - Torana - 1.49.10
    Adam - Corolla - 1.49.26
    Ray - Capella - 1.52.65
    Seamus - Celica - 1.56.51
    Oscar - Celica - 1.57.15
    Tim (broken Celica) - 2.01.15
    Now - RA23-WRX
  9. #654
    I was pretty happy with my times. Although it's a different setup, I still achieved a personal best.
    Van - What sort of times do you think we should individually be doing to be considered fast? *Considering our individual experience, setup and tyres
    There's always areas of improvement to be had. Some suspension tuning still required, but overall it's not far off. It feels better than the last track day.
    My brakes still have a few issues - Not sure if the bias is causing some issues or if the fluid is getting cooked... Probably both! It's also getting as hot as 105-110 after several laps of hard driving. I think I need some better coolant - or at least more concentrate - (I've been topping up with water since the initial fill) and a slightly higher pressure cap. Also has an oil leak from the front - suspect crankseal - and the top - suspect a small crack in the cam cover. The diff has a whine around 100kph, will get it shimmed again and change the oil.
  10. #655
    Dec 2009
    Ed your about 5 sec off the mark
    you need to get less weight in the car you removed a 2t and added the diff
    that just transfered weight from the front to the back
    having said that you do have strength in the back end now
    extreme hi temp brake fluid and a bigger reservoir may help to reduce the overheating there
    you need a tripple core radiator and/or relocate the intercooler to stop the restriction of air throught the radiator also run a hitemp engine oil and slightly overfill (again more oil better heat spread) also a bigger oil cooler may assist
    these are my views feel free to add yours people
  11. #656
    Apr 2009
    Quote Originally Posted by twentyEight View Post
    Ian was saying that there was an ra23 at pick a part on the weekend, he might be able to tell you if it had a heater core in it.
    Daily - 1994 JZA80 Supra
    Weekender - 1976 RA23 Celica
    Past - 1990 RN105 Hilux 4x4
  12. #657
    Melbourne, Victoria
    ..yeah Ed it needs more of this
    .....but less of the MR2 ....i say if you are happy with it then just do the general tweaks and enjoy!
    - Jackie Stewart
  13. #658
    Junior Member Grease Monkey RA40-Rossco's Avatar
    Newcastle, NSW
    Quote Originally Posted by Silly Rabbit View Post
    where do i sign for a pair of them?
    had a good day, lack of power and lack of driver skill is letting the car down now, corner speed is very good as is braking, nice and stable all round, might have to get it on the dyno shortly and see if we can get some more power out of her, getting over dry rooting the steering on anything that resembles a straight
    car performed flawlessly all day, only maintenance required for the day was adjust the Tyre pressures
    Toyota AE93 Corolla 20v Silvertop
    BF Mk II Xr6 Turbo Ute (tickled to 316kw)
    Datsun 180sx turbo
    Forester GT
  14. #659
    Hi Van,
    I thought .06 of a sec of Matty's GTR was a fair effort. I have a mate with a 4a turbo with similar power who has blown 3 diffs in the past week under normal driving conditions. I've built this car to last, look good, race and also be able to be engineered and driven on the road.
    If you have any practical driving advice I'd be happy to take it on board. Perhaps you should drive my car and see how many seconds can be shaved off my times. Without changing the setup. To be honest - I'm just having a bit of fun with this whole racing gig. In saying that, the car feels pretty fucking fast when it's keeping up with the big boys.
  15. #660
    Oct 2009
    I was at the tampered day on Sunday and I think Eddie did an exceptional job on the track
    Just a reminder about the BBQ. It's almost the end of September so if you wanna be part of some awesome food, let me know.
    Commonwealth Bank
    Trang T Nguyen
    BSB: 063-123
    Account: 10312096
    $25 for both days
    Thanks guys
  1. Winton 24 Hour Relay - Easter 2010
    Last Post: 03-03-2010, 05:08 PM
  2. WInton Drift Practice
