Results 1 to 9 of 9
Thread: 4agze missing on boost
    im a hardcore Backyard Mechanic LO01UX's Avatar
    Jun 2007
    Default 4agze missing on boost
    Once again my gze is shitting me
    I changed the cams on the weekend just to the bigport cams and since then wen u give it a hit it'll splutter and cough and miss and I can see the boost gauge spiking
    But when u drive it slowly boost will come on slowly and be semi alright
    Could it just be my timings out a tooth or somthing?
    BUILT NOT BOUGHT
    (\__/)
    Genuine Hotty. Conversion King old_mr2's Avatar
    Default Re: 4agze missing on boost
    Yep check your timing first buddy and go from there.
    Jun 2007
    I thought that might be it ill fiddle with it after work n see what happens
    BUILT NOT BOUGHT
    (\__/)
    Chiba
    Did you check the valve clearances when you installed the new cams?
    Jun 2007
    Yea my boss checked them for me,
    I notice last night that my fuel pressure was heaps low so I adjusted it up and took it for a drive and it was better not perfect though, so wen to increase it again and it had already dropped like 3-4psi???
    Its also not making boost as early as it was before like u have to have ur foot flat the floor to get the sc clutch to actually engage and when it does it it barely makes boost before dropping back down...
    What the hell is going on with my car????
    BUILT NOT BOUGHT
    (\__/)
    Chiba
    What is your fuel pressure set at, and what brand reg are you using?
    Also, have you checked the calibration on your throttle position sensor?
    Jun 2007
    Dunno how to check tps calibration....
    Reg is set to 35psi normally the other day it was as low as 20psi
    Its a malpassi rising rate fuel reg
    BUILT NOT BOUGHT
    (\__/)
    Chiba
    1:1 rising rate? I'm not a huge fan of malpassi, Sard is my FPR of choice, I've never had a drama with them.
    Here's how to check the TPS.
    You have to loosen the two screws as shown, then use a feeler gauge in the throttle stop to check the values at the clearances shown. Just adjust it back and forth until you get the right readings.
    Jun 2007
    Yea im pretty sure its 1:1 rising rate, im not sure if the regs stuffed I thought it may be the fuel pump as the pressure keeps dropping n its a 315,000km odd old fuel pump
    Ill try n check the tps tonight after work, is there anything else it could be?
    BUILT NOT BOUGHT
    (\__/)
  1. 4agze boost problems
    By old_mr2 in forum Tech and Conversions
    Last Post: 27-10-2009, 10:41 AM
  2. Implementing a form of closed loop boost control on Wolf v500 ECUs
    By OnAll-FOUR in forum Tech and Conversions
    Last Post: 08-10-2009, 07:33 PM
  3. 4AGZE boost upgrade
    By Robbo in forum Tech and Conversions
    Last Post: 23-07-2008, 07:41 PM
  4. 4agze missing under load
    By rollamattae86 in forum Tech and Conversions
    Last Post: 18-04-2006, 04:04 PM
