Results 16 to 25 of 25
Thread: ADRs for air intake
    Default Re: ADRs for air intake
    Wow, your cooler must be nice and efficient then (and nicely oversized).
    On the track I reckon mine (in its previous state) would have been close to 100degC
    Although, rereading your post were those 2 x 3" air ducts there with the exposed pod as well? Coz they would help tremendously.
    Quote Originally Posted by CrUZida View Post
    I'll check the numbers tonight and then give you the specs, I think you'll be surprised, I know the bloke who put his hand on my inlet manifold after I brought him in from a 20 minute session was certainly surprised
    Ducts were only in place for the enclosed box.
    My KE25 thread
    Air box is more for noise control. On cruise the plumb back BOV sits slightly open and makes a hell of a racket.
    Will get photos to show you space restriction...
    Quote Originally Posted by Invid View Post
    Hate to burst your bubble if you think a home made box will quieten anything down because on mine and many others it made the BOV louder or just as loud as without it, I assume the box and ducts just sent the noise out of the bay.
    OEM boxes and ducting have a fair bit of work go into them to reduce induction noise and what not, not something you can replicate with some sheet metal
    My KE25 thread
    My Ultra lap stated at the time of this session it was 19 degrees ambient temp and as you can see in the pic, at 15psi and giving it a fair hiding I saw a peak of 24 deg C down the main straight. My intercooler core is a small front mount (480mmx240mmx38mm). When I pull in after a session my inlet manifold is cool to touch
    The key is the intercooler water sprayer
    My KE25 thread
    Hahaha, thats cheating (but impressive none-the-less)
    I'll see if I can dig up some logs without running it, if I can't find any I'll run a session next time with it switched off for comparison.
    On the old ECU which couldn't log but could store the max temp value it'd see 12 - 15 degrees above ambient with no intercooler sprayer in place at the track.
    The intercooler sprayer has been one of my best bang for buck projects for sure.
    My KE25 thread
    Brisbane
    Just find a big fuck-off airbox from a factory car, and use that either with a K&N panel filter, or mount a pod filter inside it.
    Something like a Falcon or some type of 4WD would be a good starting point.
    Quote Originally Posted by Shifty View Post
    even though he said....
    there is crap all room for a standard air box so I'm going to have to make a custom one
    My KE25 thread
    It's probably a moot point now, but I thought I's post a photo of how much space there isn't.
  1. JZA70 and MA70 Specifications
    By twentyEight in forum Tech and Conversions
    Last Post: 18-12-2016, 10:18 AM
  2. Adapting Ford 2.0 Intake Manifold to 2T/3T
    By restorolla in forum Tech and Conversions
    Last Post: 04-09-2006, 07:56 PM
