Results 1 to 2 of 2
Thread: what ratio diff should i use?
    Default what ratio diff should i use?
    hey i have just installed a new engine into my old hilux 81 rn31 and i am still upgrading everything else in the drive line to match.
    my question today is if i have a 3RZ engine, W56 box 235/45r17 wheels, what ratio would be suggested to run in the diff. i have no idea what the rzn149 hiluxs come with, however i do realise the box has a really short 1st 2nd and 3rd gear so would it be advisable to run a taller diff then the standard rzn149 diff? the ute doesnt do work, towing etc will just be a daily when it is finally done.
    also would it be better if i changed the box to a w57 with better driving ratios what diff should i use then?
    anyhelp will be appreciated
    leroy
    Junior Member Grease Monkey styler's Avatar
    Jun 2006
    Default Re: what ratio diff should i use?
    check out a gear ratio / wheel size / rpm / speed type calculator, theres a few on the net and you input in different values to calculate your desired parameters.
  1. diff ratio options for ke70
    By J0RD0 in forum Tech and Conversions
    Last Post: 01-07-2009, 03:44 PM
  2. Replies: 9
    Last Post: 18-04-2007, 08:39 AM
  3. rt132 corona diff ratio?
    By dundee230966 in forum Tech and Conversions
    Last Post: 21-02-2007, 10:31 AM
