Results 16 to 19 of 19
Thread: 4age Oil Leak
    perth
    Default Re: 4age Oil Leak
    that front corner has the oil feed to the head, i have had them leak there before.
    as said, clean it down and run it without the cam covers and watch it leak.
    Feb 2009
    there should be a black metal shield between the motor and timing belts. usually looking at the back gives some indication of where the oil has been coming from.
    unfortunatly the lower belt drive sholuld just slip off by hand.
    Toyota Hilux 1998 ln172r x-cab D/T
    Toyota Corolla 1986 ae82 twin cam 16
    - Distributor, outer AND inner seals (Toyota does NOT sell nor list the inner seal as a part number)
    - Crankshaft front oil seal
    - Cam cover seals
    - Cam seals
    These are common places for oil leaking on a 4AGE, in that order, except cam cover seals which may leak due to poor refit from being removed and replaced many times. To get to the crank oil seal you'll need to remove the timing gear with a timing gear puller. Don't bash/prise it off by other means, you'll only break it and I'm not sure if Toyota still sell them.
    perth
    yes, they still sell the crank gear ($40-50 i think) i bought one not long ago.
  1. CT12A Oil Leak (Rear).. Need advice
    Last Post: 25-03-2007, 07:28 AM
  2. 4AGE 86KW TVIS V 100KW 4AGE + Shocks
    By GeeEss in forum Tech and Conversions
    Last Post: 17-01-2007, 08:51 PM
