Results 1 to 7 of 7
Thread: ST162 Coilovers maybe ST184??
    Jan 2007
    queensland
    Default ST162 Coilovers maybe ST184??
    i've searched a bit around the forums,
    i've read that ST185 fits the ST165 front end, but thats about as far ar it goes, or does it?
    do they have the same top plate/mount it's not a problem to knock out the studs and drill new ones..
    through my own bits of comparing.. side by side the ST162 shocks, and the AE92/101/111 shocks have the same (or 99% close to it) dimentions, aside from the celica being a little fatter, and the rear swaybar tab, every so gently needs to be 'manipulated' a little bit just changing the angle.. not much.. just a few mm.. coilovers on the other hand
    then just need to redo the top plates with the ST162 bolt pattern, or is there the much simpler way of ISC, or what ever now making a set of coilovers for the ST162?
    cheers.
    Jan 2007
    queensland
    Default Re: ST162 Coilovers
    http://justjap.com/store/product.php...cat=270&page=6
    anyone know if ST184 coilovers will fit in??
    the front camber plates look like the have the same PCD (it's about 113mm hole centres, in an equalateral triangle)
    just need to confirm the rears.. anyone have a pic of a rear ST184 strut top?
    Default Re: ST162 Coilovers maybe ST184??
    strut top hole spacing is same. i can't remember if the actual orientation is the same or not. but can confirm they fit up fine.
    rears nfi sorry
    dont eh 184/185 have a larger hub-to-strut bolt?
    PM Robst162. he put a set of front 185 coilies in his and had to use the 185 front hub
    Jan 2007
    queensland
    cheers for that, i think i saw it on ozcelica... he put the teins in??
    Jan 2007
    queensland
    yep, that all works with the ST185 - ST165..
    they actually make coilovers for the ST184 now.. so i was wondering if they could be put into the ST162...
    hopefully the rain will hold off, so we can get to the wreckers on the weekend!
  1. e153 gearbox in a st162 with 3sgte gen 1?
    By trd-st162 in forum Tech and Conversions
    Last Post: 26-10-2006, 11:03 PM
