Results 1 to 12 of 12
Thread: Do I need a new water pump?
    Default Do I need a new water pump?
    Hi all,
    I was after some advice from the masses, I have a 4AGE with a water pump that is about 6,000 km old, the catch is it has been sitting for about 20 months with only hand rotation about once a week. The engine has been drained of coolant over this time.
    I have the majority of the front of the engine apart at the moment and I saw this residue on that seems to be coming out of the pump. I understand the "breather" hole it there to allow coolant to leak so a failed water pump can be spotted.
    I'm guessing I need a new pump unless someone can suggest otherwise?
    Also, how often does the rear of the pump housing need to be changed?
    Aug 2009
    Default Re: Do I need a new water pump?
    yes water pump is f**ked... and also.. while everythings apart for the sake of less than $80 would you even second chance it??
    Hooligans Holiday Grease Monkey kickstartRA28's Avatar
    Apr 2009
    Quote Originally Posted by pandaah View Post
    Exactly......easier to do now than later.
    3TGTE might be old but it can still hammer along.
    Fair enough, thanks guys. I do know I'd be taking a risk, I was was trying to gauge how much of a risk it would be. I suspect it had failed before it sat for this time which begs the question why the hell did it fail after such a short amount of kays?
    when 4a pumps go they seem to let go the first seal inside before the first bearing, causing coolant or in your case rusty water to leach out of that hole. It's dead
    Oct 2008
    TAS
    it looks like toyota red residue too me?
    1983 Toyota Celica Supra
    It wasn't running Toyota red since rebuild, in hindsight I would have liked to but I won't worry about it now. I'll leave it for a future build.
    Opinionated Arsehole Backyard Mechanic
    Edited post!
    Punctuation is the difference between...
    'I helped my Uncle, Jack, off his horse'
    and...
    'I helped my uncle jack off his horse.'
    Quote Originally Posted by 4DaDrift View Post
    Looks like the perfect excuse to install a Davies Craig electric water pump
    As others have said before me, it isn't an area worth taking a chance on, unless you like doing rebuilds.
    not unless you want a pump that doesn't work right, hehehe
    crap product, if you want to know why PM me
    Edited post!
    and...
    got 71? Grease Monkey cooter's Avatar
    wa
    the davies craig aint that bad. ive had one running my BT for a couple of years now. no dramas. have herd of the occasional one leaking but
    Te71 Corolla Levin, Blacktop 20v
    Te71 Corolla Levin ex Rally Car 2tg.
    Te71 Corolla Hardtop 2dr Sedan, 2tg/3t waiting
    Ke70 Corolla 4dr Sedan
    Ae86 Corolla sprinter 4ac
    Corolla Feind
    still got a conventional thermostat in the system?
  1. Replies: 18
    Last Post: 03-02-2010, 12:30 PM
  2. 4AGE water pump
    By Invid in forum Tech and Conversions
    Last Post: 26-04-2009, 06:33 PM
  3. 18RG Water Pump
    By DingDing in forum Tech and Conversions
    Last Post: 16-10-2007, 09:06 PM
