on the sumitomo (standard nissan GTS-t calipers) they have a ridge on the end of the piston, i used a couple heavy duty pry bars and lent against the caliper to get them out.. lubricate them with whatever you want trust me it doesnt matter... but they will come out it make take some muscles but theyll come
when the pistons are out replace the inner seal for EACH piston.. linish the piston on a wire wheel and clean everything really well with brake cleaner (its the best cos itll evaporate or wipe off without leaving a residue, and itll get rid of the wd40 or crc you used to unstick the pistons...
once youve got everything cleaned and dry, new seals and your ready to go, lubricate the pistons and seals with rubber grease.. make sure its rubber grease cos some normal greeses are made with petrolium which will eventually eat away at some rubbers.. then put the outer seal on, and the wire clip to hold the outer seal on and away you go!
have fun!
