Some other's may be able to give you direct replacement lists, but the best way would be to take some measurements & compare with other Toyotas
The 3 points of interest:
centre point of axle
centre points of the bolt holes that secure the caliper to the hub/steering knuckle.
Measure between all three so you end up with a triangle.
Find similar size toyota wrecks at the wrekcers/breakers and measure up.
Even Celica/Carina E may be able to fit if you have brake rotor redrilled for 4 stud instead of 5 for a cheap brake upgrade.(check the measurements including caliper offset first).
