Results 1 to 15 of 29
Thread: 2TG Fuel Pressure + Solex
    Too old to be a Grease Monkey
    Aug 2008
    Default 2TG Fuel Pressure + Solex
    Hi All,
    Just wondering if one of those VL Commodore electric fuel pumps will have too much fuel pressure for my solex carbies? Or is it ok to get away with? Not going to be tracking the car., just street driving and nothing crazy.
    If I need a regulator can someone advise which one and where to find one?
    Nathan
    Aug 2009
    Default Re: 2TG Fuel Pressure + Solex
    turbosmart rising rate fuel pressure regulators are really good.... see how you go, id go get ahold of a fuel pressure gauge and test your car as is, put the pump in and test again.. then limit the fuel pressure with the regulator if the new fuel pressure is higher... but i think youll be right
    Aug 2008
    Thanks,
    Problem one is that the engine has no fuel pump and I am not sure it ever had one? I might just try the pump and see what happens! I believe that the 2TGs wanted somewhere near 3.5 PSI which I read somewhere on here.......
    Can you regulate those pumps with the voltage with no ill effects?
    Nathan
    A quick google tells me the high pressure VL pump is 40psi. That will be wayyyyyy too much. It needs to be around 4psi.
    The low pressure VL pump is 3psi according to google.
    Which one have you got?
    Now - RA23-WRX
    Aug 2008
    Hmmmm Wish I knew!
    Will test it when I get some fuel lines.
    I am hoping that I have the low one. But I bet I have the high one!! Just murphey's law!
    Is there a way to check easily.....other than pumping fuel?
    Nathan
    Does it have a part number on it? the 070 was the vl efi pump.
    Do you know what the pump was from? The 6 cyl's were all the efi'd nissan engines so had high pressure pumps. Only the V8 (which was still carbied) would of had the low pressure pump. (I assume it had an electric pump which would be a low pressure one, but i always thought they were mechanical pumps)
    Lick my hairy Backyard Mechanic Turdinator's Avatar
    As you already said you should be aiming for no higher than 3.5psi for carbs like solex's and webers. I've never tried it but I would think regulating 40 psi to around 3 psi wouldn't be the best idea. I imagine it wouldn't do much for the longevity of pump and regulator. Low pressure pumps are pretty cheap unless you go for something like a holly.
    Aug 2008
    Hmmm I have the 40 PSI pump.... Doh!
    Back to the wreckers I say! What a pain.
    Should be able to swap it hopefully.
    Will try to look for a carbied V8.... but dont really like my chances. What other fuel pumps provide about 3.5 PSI? Or should I get a new one?
    Cheers all for the help.
    I would get a new one. They can be pretty cheap.
    Stay away from the facet pumps though. While they work pretty well, they are noisy as a mofo. (even when rubber mounted)
    Whatever pump you get you'll still need a pressure regulator. Speco make a cheap one that you should be able to get at any parts store.
    PS. If going second hand I would look at carbied japanese cars, They have sweet pumps which are fairly quiet, I had one from a mitsubishi something or rather on mine.
    Some low pressure pumps are self regulating. The one from the mitsubishi i had was.
    Junior Member 1st year Apprentice Killa_Ta22's Avatar
    I'm in the process of getting mine all running.
    The car has a vl fuel pump, it was connected up to a 2tgeu.
    just done a 2tg twin solex swap job, so i ordered one of those filter kings. built in filter, pressure reg and gauge. i think i may need to change to a lower pressure pump also since you guys mentioned that
    Aug 2008
    That style of pump from the mitsy sounds good. Any idea which model?
    Nathan
    Sadly no I don't know what it was from.
    I will get the part number of it and try to look it up dood.
  1. 1GGTE fuel pressure
    By sleepy1g in forum Tech and Conversions
    Last Post: 08-09-2009, 08:40 PM
  2. Replies: 38
    Last Post: 02-06-2009, 02:55 AM
  3. Twin Carb fuel setup
    By soulfire in forum Tech and Conversions
    Last Post: 18-12-2008, 03:38 PM
  4. 2TG fuel line problem!
    By Stock_22 in forum Tech and Conversions
    Last Post: 30-10-2007, 07:13 PM
  5. Replies: 1
    Last Post: 13-12-2005, 03:42 PM
