Results 1 to 5 of 5
Thread: 1GGTE fuel pressure
    Jul 2009
    Default 1GGTE fuel pressure
    Hi guys,
    Whats a good fuel pressure to run the gen 3 1ggte on and what is the factory pressure
    Brad
    1985 RT142, 1GGTE,.now with t67-25g
    2009 Ford Fiesta LX
    1970 Ford Cortina MK2 440
    Default Re: 1GGTE fuel pressure
    I'm fairly sure that the factory pressure is 42psi.
    Before anyone can recommend a different fuel pressure you'll need to tell us a) why and b) what mods you have (to the fuel/electronic system)
    The old One Backyard Mechanic
    Checked my 1ggteu manual - fuel pressue is between 2.4 and 2.8 kg/sq cm, or in real language 34 to 40 psi. I think that you can assume 2.55 kg/sq cm or 36 psi 'cos that is the pressure recommended to measure flow of injectors (think it is 71.5 to 76 cc in 15 seconds at 2.55 kg/sq cm). Now remember the engine has a rising rate regulator which from my collection raises pressure to some 50 psi depending on boost - won't bet on the max value as it is some time since I measured it.
    Just a little information - when I had the standard motor in the car I had the opportunity to measure the difference between output (killer wasps) with the vacuum hose disconnected from the raising rate regulator. Instead of the mixture going to some 11.8 - to 12 under max boost it remained in the low 13teens and gave some 11 extra rwkw.
    Something to try if you have your car on the dyno
    Cheers Craig
    It's not a rising rate regulator, it'sa linear rate regulator, which increases the fuel pressure by 1psi per 1psi of boost.
    Gen 1 and 2 running different pressured to Gen 3
    Gen 1/2 run 38psi, Gen 3 42psi. (at 0psi boost, 0 vacuum)
    Jul 2009
    thanks guys, very helpful gives me a point to start from.
    2009 Ford Fiesta LX
  1. Replies: 38
    Last Post: 02-06-2009, 01:55 AM
  2. Fuel cooler / fuel temp
    By Pearce in forum Tech and Conversions
    Last Post: 12-05-2007, 07:55 PM
  3. fuel pressure and 4age
    Last Post: 15-04-2006, 05:47 PM
  4. Sard fuel pressure reg
    By 3t-RA40 in forum Tech and Conversions
    Last Post: 08-02-2006, 07:56 PM
  5. Replies: 1
