Repeat the entire process above on a second identical igniter.
Once you have 2 igniters modified as above stick them on your mounting bracket of choice
join the brown 12V power wires on each igniter together.
These will ultimately connect to a 12v source.
In toyota systems it should usually be power supply south of the Engine Main Relay which activates when the ignition switch is in the ON position.
wherever you mount them make sure the mount can earth...
it is crucial that the igniter casings have a good connection to earth.
with this set-up I used aluminium for the bracket so I have had to use additional wires to earth the casings.
But if you are using a metal bracket and it is secured to the chassis then it will be fine.
The remaining blue wires go to the 2 individual ignition outputs of the ecu.
You just have to make sure that the output corresponds with the right igniter for the firing sequence.
And that's basically it...
Credit due to Autoshop101 website and the 2006 thread by The Witzl titled "Toyota Distributor and DLI Ignition Systems - explanation and guide" for helping me get my head around this stuff.
