there is a torsion bar which acts as a spring that is splined to one of the wishbones.
you can raise or lower the front suspension via a adjuster bolt which is mounted to the other end of the torsion bar just past the end of the gearbox. if you want to adjust it just be careful as the last 4wd i did the bolt snapped and went through the floor a tore a hole i then had to repair. neil
