Results 16 to 30 of 45
Thread: supercharged twin turbo 2jz - lets brainstorm
    Default Re: supercharged twin turbo 2jz - lets brainstorm
    Been done.
    But I'm with the others. If you're here asking what the merits might be or how to do it, the project is probably going to be a bit beyond you. If you're here wanting us to piss in your pocket, I suggest you move across to boostlosing.com. Performanceforums.com will also give you a warm reception.
    Nov 2007
    Probably better to put the 2jz in your car first, see how you like it then decide what you want to do.
    Aug 2009
    LOL @ some of the responces, i was just brainstorming..... as obviously there are better ways out there then possibly what i had in mind..
    i didnt even put a price limit or a time limit to build it, if it was going to be an awesome setup to run i dont see anything wrong with taking 5+ years to build an engine...
    i was actually going to experiment with my 1ggte firstly but gauging on the noob responces like shifty i might just not bother to ask what everyone thinks, like seriously... high five man
    Nov 2007
    Quote Originally Posted by Shifty View Post
    Fully kitten workshop!!!
    Somebodies Jealous
    Sep 2009
    Northland
    heres few pics you might like
    Junior Member Domestic Engineer 1jz68u's Avatar
    that looks like a shit fight. and isnt that a 1J?
    Glenn
    Current Ride http://www.toymods.net/forums/showthread.php?t=41123
    Previous 3SGTE ST162, 1JZ Cressida 215RWKW-ET 13.318, Celsior, XT forester, 3SGE KE70.
    Quote Originally Posted by NME308 View Post
    You do of course realize forgiveness is easier to gain than permission right???
    Cheers, Jason
    Sep 2009
    Northland
    Yep was a shit fight,Made out of scraps, was fun tho,yea it is a 1jz ,
    Junior Member Grease Monkey seamonsta's Avatar
    May 2007
    Hills Area Sydney
    Quote Originally Posted by RobV View Post
    I think you could just squeeze a small JET engine onto it for even powahhhh. Did this engine actually run or not???
    Sep 2009
    Northland
    Haha True that,
    Yea it sure did, originally ran with the SC14 and A T66 P-Trim,.96.in a compound setup, found T66 way to small to flow say 500hp at 6psi, and i had overdriven blower 2 much, changed to twin t61 compressors geared blower dwn to 10psi, after compounding 27psi avgas w/15% Methanol mix, unfortunately I was using a Greddy Emangle Ultimate for tuningand was unable to get it 2 run properly with early firmwear, and ended up using it as a FCD and extra injector controller, and adding more methanol 2 stop knock as could not adjust timing. with a techedge W/B and knock head phns, used 2 sets of 440cc injectors 1st set controlled by factory ecu with V3 Sti Map sensor, and emangle controll 2nd set 440s seeing rnd70% duty on second injectors rnd 13;1 a/f 33psi,, unfortunately car was crashed around 4 years ago ,am making a much improved setup at mo with twinscrew blower and gt4508r/hx50 28cm turbo, will all fit under bonnet!!
    May 2007
    Hills Area Sydney
    My head hurts just trying to comprehend all that!! Great effort though, what car is it all going into? Might need a full chassis truck to hold the weight of the beasty motor.
    school holidays
    what i was thinking.
    all these "turbo + supercharger = bestest awesome idea that i just had evar" must take up a lot of room.
    cant we just ban the op's?
    Haha True that,
    Nice concept if a little haphazzard in application
    here was my effort
    Sep 2009
    Northland
    cheres, its a jza70r
    Sep 2009
    Northland
    wow thats nice!!! was interesting seeing the results,n cost bugger all in parts to build
    wow, the electronics sound like a nightmare, how much power did you make?
    Glenn
    Cheers, Jason
  1. **HELP** Twin turbo to single 1jz setup.
    By DLA11D in forum Tech and Conversions
    Last Post: 11-07-2011, 11:06 AM
  2. mr2 corvet 1UZ twin turbo or 2JZ-GTTE
    By bje10s in forum Tech and Conversions
    Last Post: 09-06-2007, 04:26 PM
