Results 16 to 30 of 42
Thread: 1uzfe ra28 weight balance
    Default Re: 1uzfe ra28 weight balance
    Quote Originally Posted by TurboRA28 View Post
    I don't want to upset the car too much as it's predominately used for track days and dont want it to be an understeering pig.
    Removing as much weight as possible forward of the front axle line will help enormously.
    Most people will start talking about weight distribution, but that doesn't tell the full story. Moving a 12/15KG battery from the front left corner of the car pictured wouldn't have a huge change in front/rear weight distribution, but the change in the cars polar moment of inertia will be significant.
    I looked at moving the 185KG engine in my Alfa 75 back about 30mm. The calculated effect was a reduction of the engine polar moment of inertia effect on the car of about 5%. Removing the 15KG battery from the front left had a calculated effect of over 3 times that of moving the engine back.
    Bumper bar and brackets could be drilled. Aluminium radiator and light weight fan (the factor 1 in my Alfa is strangely heavy). Make the anti-roll bar out of large diameter Chromoly tube. Fibreglass/carbon fibre bonnet.
    Yeah confirmed with the engineer.. No good can't be done.
    I thought there was a few v8 celica's getting around these days...
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    User Conversion King
    NWA
    ICV it.....
    hello
    Whats ICV?
    individually constructed vehicle
    NWA
    individually constructed vehicle.
    its probably different for different states but if there is significant modification then the vehicle can be classed as ICV.
    i think the engineering cost may be moderate
    hello
    Probably close to it.. with steering mods, irs in the pipeline, etc etc..
    vic
    problem with ICV, you have to comply with current (ie 2009) emission standards, and i think crash standards etc etc.. sooooooooo much more work you have to do for it to be eligible.. not worth it imho
    Plonka is on the money with shifting weight.
    You don't have to comply with crash standards but you do need to comply with current emissions and ADR's
    Joel, if you were to go IRS and modified the front sub frame you may qualify for ICV. Generally ICV is for non production chassis or production chassis that have been widened, lengthened or had all the cross members relocated. modifications to you inner guards + IRS may put you in that area if the engineer agrees.
    Simon
    Beige.... The new Black!!!
    The guidelines to classify your vehicle as ICV is also outlined in the VSI06 i linked above. It wouldnt be that hard since you have already change one major structual member (thats if the front crossmember is considered major structaul member).
    Gotta love SA.
    If an engineer will sign off on it and it passes emissions, your good to go
    No sign of those rules changing either, RTA says NCOP doesnt look like itll come into effect any time soon.
    So maybe a street legal turbo 1UZ RA28 is in my future
    Junior Member Backyard Mechanic bigmat's Avatar
    sa
    mine has icv well thats what we applied for. as it stands my car is a one of creation that meats all adrs on all the mods i made. in regards to emissions my car car had to pass the current limits set down by the manufacturer to pass. all up to do this cost me around 4k and i would do it again as now i know how to do it.
    cheers mat
    What about trying to register it as a GT celica or something? As I would have thought they were over 1100kg with the larger diff, ac, etc?
    That was an option i considered when planning my ra28 1uzfe. If you can write explaining that your car possess some GT features (diff and whatever else you can make up) which puts it over the 1100kg weight?
    Or, you could just semi mid mount 1jz it.
    Heaviest RA35 is 1090kg. (The GTV model) (This is the weight from the brochure, in Japanese so don't know if that's wet or dry)
  1. 1UZFE into an RA28
    By coxy in forum Tech and Conversions
    Last Post: 28-11-2006, 08:11 PM
