Hi mate
Honestly your first port of call should be the exhaust. It will be cheaper, easier, and give a much larger gain than an ECU... and ECU is more about capitalising on existing modifications rather than giving an improvement on an otherwise standard car.
It is unlikely that you will find a 'plug in' option for such an uncommon car here in QLD, so you will either need to go piggyback (unichip, e-manage, etc) or full stand-alone (Adaptronic, Haltech, etc). You mentioned something about an auto in another thread, this is an important point as a lot of ECUs are unlikely to support an electronically controlled auto gearbox.
If so your best option is a piggyback/interceptor as this runs the standard ECU and just intercepts/modifies fuelling etc so all your standard gear runs as normal... or possibly a standalone ECU spliced in to just control fuel and ignition and the factory ECU otherwise left in control. I don't know much about the complexity of the latter. The best option is full standalone but if you want to run an auto then one of these two options will likely need to be taken.
As far as extra boost goes you will probably find that you're running 10-12psi from the factory... speaking generally an increase to 14psi on an otherwise standard car will only create more heat due to the restriction of the factory exhaust etc... and any performance gains will be minimal and certainly a trade-off as far as long-term reliability goes.
